E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
Random speedo death!!
So, I replaced my Odometer gears with the garagistic kit. Thats finally working again. But here's my issue: After driving the car for about half hour or so, my speedo will randomally die and drop to zero. I have to finger around the back of the plug and push and play with the wires on the back of the cluster to get it to work again. I went to the junkyard and replaced the yellow, blue, white slip on lock connectors that the plug goes into. Still no good. Not sure what else to do besides re-wire the connectors hoping that will resolve the issue. Anybody having this problem? It's very annoying because I can't buy a new driver kick panel till I resolve this issue, otherwise I can't finger the back of the cluster.
1985 335i ![]() Black on Black coupe 5spd Tokico lowering springs, KYB struts and shocks, BavAuto strut bars, SPC adjustable camber plates, Ireland Engineering rear toe and camber kit, Sparco buckets, Rota Torque 16x7 fronts 17x9.5 rear, Hella headlamps with HID conversion, all red taillights, MSD coil,M30B35 swap, Mustang GT Injectors, Port/Polish
have you tried the gear in the tranny/diff?
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
