Old 03-12-2013, 08:37 PM
dgalby dgalby is offline
Mein Auto: 2008 BMW 535xi
Daytime Running Lights - Can I replace on my own
My left daytime running light it out (both left lights). What light bulbs do I need to purchase to change these? I got a quote from the local deal and they were $240. If one side is out do I need to replace sides? I was considering upgrading to 'angel eyes' but I don't know what bulbs that comes with. Any suggestions?
Old 03-12-2013, 09:03 PM
jim165 jim165 is online now
Mein Auto: 2008 BMW 550i Sport
Search "angel eyes". Bulb type is H8. You can change them yourself in 10 minutes.
2008 550i Sport-a.k.a. Hot Kraut Garbage
Others:
2006 Corvette Conv, Z51,6sp (wife)
2007 Honda CBR1000RR Sold
2005 Triumph Daytona 650 (wife) Sold
Old 03-15-2013, 11:12 AM
patryan patryan is offline
Mein Auto: 535xi
+1, 5 minutes for the first bulb and 3 minutes for the 2nd.
(8/2007-4/2016) 2008 535xi Platinum Grey, Black leather, bamboo anthracite, anthracite headliner, premium, sport, cold weather, ipod, L7 stereo
(4/2016-present) 2013 535i xDrive, Black/black
Old 03-15-2013, 12:59 PM
Thanks for the information. If I just replace the daytime running light what is the bulb type? Where is a good place to buy either the daytime running lights or the angel eyes? Are the angel eyes worth the extra cost? Are they any different from regular bulbs? Sorry for my lack of knowledge....a friend just said they looked "cool".
Sent from my SPH-L710 using Bimmer App
Old 03-15-2013, 04:56 PM
Oceans10's Avatar
Oceans10 Oceans10 is offline
Mein Auto: BMW 535i + 535XI wagon
http://www.burgertuning.com/BMW_LED_angel_eyes.html
http://burgertuning.com/BMW_Angel_Eyes_H8_Bulbs.html
2 options. The second one is dirt cheap, but doesn't last as long as the LED types. Also not as bright, though much better than the yellowish stock ones.
Audio: Jehnert Flatline speakers, Mobridge M1000 DA2 prepro, Helix P-DSP, Zapco Z-150.6 amp, CIC iDrive upgrade
Performance: MHD Pro Tune, AR Downpipes, ER FMIC/CP, DCI, RB turbos and inlets, KW V2 coilovers, Fuel-It Stage 2 pump w Ported fuel rail, Mfactory LSD
Old 04-14-2014, 11:16 AM
surreal1221 surreal1221 is offline
Mein Auto: 535i 08
Hate to bring this thread back to life, but for an E60, is there a reliable DIY somewhere? The videos on YouTube are somewhat contradictory.
Have basic 3100k H8 from Autozone, just need to replace left bulb quickly and then I'll investigate going to an LED solution.
**Disregard: Found the proper video in another thread, just took way too long...**
Old 04-14-2014, 05:49 PM
Rebound X3 Rebound X3 is offline
Mein Auto: 2010 528Xi
If you have the owner's manual, it tells you how in there.
Old 04-14-2014, 11:56 PM
sean19761 sean19761 is offline
Mein Auto: 2008 528xi BMW
Originally Posted by dgalby View Post
my left daytime running light it out (both left lights). What light bulbs do i need to purchase to change these? I got a quote from the local deal and they were $240. If one side is out do i need to replace sides? I was considering upgrading to 'angel eyes' but i don't know what bulbs that comes with. Any suggestions?
this what i did when i had the same issue. I research trough youtube put year make model just to see where where and how to remove lights. Then remove it yourself. Once remove there should be serial number around the bulb. Type number in google and all these options pop up. Find a website call these stores which at time located in another state or out of country. They will help. Good luck
Old 04-07-2015, 06:32 AM
Mein Auto: 535xi
Dealer quoted my about $150 to change one... I started laughing. Had already done 1 a year ago so I knew how easy it was. 3 minutes and 2 bulbs for $30 from Burger (Arc Angel H8). Twist off a cover, 90 degree twist of the bulb, pop off the connector, and reassemble. No tools required. Add 5 minutes for your first one.
Old 04-07-2015, 08:25 AM
wyb's Avatar
wyb wyb is offline
Mein Auto: A car
This is the thread I started about how easy it is to change the H8 / Angel Eyes on the E60 I have:
http://www.bimmerfest.com/forums/sho...d.php?t=830775
535i XDrive | Alpine White w/Black+Natural Leather Interior
Old 04-09-2015, 05:58 AM
ElikMalikov ElikMalikov is offline
Mein Auto:
Yes you can change or you will pay $150-200. I changed in 15 minutes both of them. I used YouTube . Just search in the YouTube and It will help you.
I hope you can change!
Old 04-09-2015, 06:42 AM
I live in Maryland and are you sure it will only cost around $150-200. The part alone is $400 and labor is probably the same
Old 04-09-2015, 07:20 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
I thought DRL is the low beam Xenon not angel eye rings on E60?
in any rate, I turn my DRL off on iDrive cause it'll burn the D1S/D2S bulb sooner, not sure how hard to replace that one on E60 it's a bitch on 3-series and X5/X6 (the splash guard in the fender needs to come out)
Old 04-09-2015, 08:56 AM
98PoleCat's Avatar
98PoleCat 98PoleCat is offline
Master of my domain
Mein Auto: 2007 550i
Pre-LCI, the DRL is the halogen flash-to-pass beams (with lower output).
LCI, the DRL is the angel eyes.
Both can easily be changed.
Old 04-09-2015, 12:42 PM
I've had the same issue with my 2008 528xi. I used this website call carcarekiosk.
