E36 (1991 - 1999)
Old 03-12-2013, 09:23 PM
Mr Gusta's Avatar
Mr Gusta Mr Gusta is offline
Fireballs inc.
Send a message via AIM to Mr Gusta
Mein Auto: big turbo hellrot sedan
Mr Gusta's budget/hobo/high comp/e85/holset/ebay bottom mount build
still waiting on a few things, I will post pictures (sorry if some of you hate the hipstergram pics)
m52b28 crank
ebay m20 cxracing rods
ebay tial rep Bov
new glyco main and rod bearings
f1 racing gripforce stage 4 unsprung 6 puck disc with self adjusting pressure plate.
weird looking t3 externally wastegated holset hx40
compressor
54mm inducer
84mm exducer
turbine
76mm inducer
69mm exducer
ebay t3 cast bottom mount manifold
sorry for the sepia lol
Im going to be running a walbro 400 in tank pump, along with 800cc injectors, and Rk-tune for ethanol
a few places I've read state that m50 pistons with m52 rods and m52 crank = 11:1 comp, Im going for that and even higher if the pistons dont make contact with the head
been crazy busy.
distracting side project is my buddys e30 sedan
will be getting a high comp m54b30 on e85 fully bolted rk-tuned with a zf 5speed and 5lug swap.
put the pistons on the rods, after I cleaned the m50 pistons up, also got a pair of s50 cams from Jordan, heavy on the rust but started cleaning them up.
Dirty girl
after the first pass
pulled all the rings off the pistons and they were too wide so im putting in new rings that I picked up from George at ICS (great guy!)
installed a piston and rod after I honed the cylinders to make sure it doesn't stick out above the deck.
Dat 2.8strokebaby
sits herrafrush with those m50pistons brah
Turbo lag is just a headstart because the chase is more exciting than the win - Abraham Lincoln
Old 03-12-2013, 09:24 PM
Mr Gusta's Avatar
Fireballs inc.
I removed the piston and rod and crank that I installed with the old bearings and mismatched caps hand tight just to give me a rough idea as to where the piston would travel.
so I installed the arp main studs after I cleaned the threads and the bearing receivers
took a break
okay back to work! I pushed all the bearings into place, and made sure there was no debris on or under them.
Lucas green super tacky super thick assembly lube on the bearings.
dropped the crank in and spun it to distribute the lube
Put the caps in order facing the right way with the bearings pushed in each cap and more lube on each bearing.
washers on
Arp lube on each stud
torqued and ready to go
Old 03-12-2013, 09:33 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
I are green with envy Frank. Looks like how she's supposed to be!
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 03-12-2013, 09:36 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
Love it!
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 03-12-2013, 09:52 PM
Mr Gusta's Avatar
Fireballs inc.
thanks ed!
Originally Posted by hornhospital View Post
Love it!
thanks ken!
Old 03-12-2013, 10:25 PM
Gooby's Avatar
Gooby Gooby is offline
Sexy Sax Man / Kebab Lord
Mein Auto: 1995 M3
Oh man now you'll DEFINITELY be faster than me :/
Lol jk...when's the eta? How much power are you aiming for?
Instagram | @randytheus
Old 03-13-2013, 05:41 AM
crisscross's Avatar
crisscross crisscross is offline
Just living MY dream
Mein Auto: 1995 M3 Boston Green
I wonder how much you will be able to pull on those s54 or euro swapped e36's
Nice work Frank!
-Alan
Member #2 of the Boston Green Mafia BMW-CCA #457574
1995 BG M3(sold) 2000 TiAg 4.4l X5(sold)
-2000 F250 V10
-2004 GMC Yukon Denali
-I do the things today that others won't do, so I will have the things tomorrow that other won't have....
Old 03-13-2013, 07:18 AM
Mr Gusta's Avatar
Fireballs inc.
to be honest at 10psi te goal is 500whp and then after a while I will turn it up till the turbo runs out of breath
Nice work Frank!
It will be massacre, s54 e36's trap 110 and a 600whp e36 is in the 135mph trap range (zr1 traps 130 out the box)
really excited to find a 2.79 diff, that will help me put the power down in every gear and stay in the powerband for a longer period, top of 3rd gear would be 115mph and 4th should be 158, and maybe we can raise the rev limiter in 5th so I can do 200 in 5th
Old 03-13-2013, 07:35 AM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
yes.....
how much power would this build produce without boost? same as m52?
are you using the m54 block?
-Dino
Old 03-13-2013, 08:17 AM
Mr Gusta's Avatar
Fireballs inc.
Originally Posted by Dino1394 View Post
yes.....
It would produce the same power as a fresh high compression m52 with s50 cams
I'd figure around 240whp maybe more with bolt ons and an aggressive tune.
Old 03-13-2013, 08:37 AM
dc_wright's Avatar
dc_wright dc_wright is online now
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Originally Posted by Mr Gusta View Post
I can do 200 in 5th
It takes a serious aero package to run this kind of speed and keep it between the ditches..... but it's cool to have the potential to get there!
Nice job Frank! Saw earlier that you did it right with the main caps and kept track of the location and orientation.
Can't tell you how many people I know that didn't pay attention and then found their crankshaft hard to turn or even locked up and couldn't understand why when they went to reassemble.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 03-13-2013, 08:43 AM
Mr Gusta's Avatar
Fireballs inc.
I did the math it would take around 430hp to get to 200 and the hp lost is around 340, turnt up im positive I should be above 600whp, who knows its just nice to have that 2100rpm 60mph cruising speed
Old 03-13-2013, 09:45 AM
Mr Gusta's Avatar
Fireballs inc.
Next year or 2 maybe I'll skidplate the whole underside of the car and try to make it more aerodynamic so I can bring it to the texas mile event one day
I just want the 200mph club tshirt
Old 03-13-2013, 10:34 AM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
Do work Frank! Whats your budget on this build?
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2007 328i DD
Old 03-13-2013, 10:56 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Looking good.
GGC BMW CCA #443004
Join the BMW CCA!
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 03-13-2013, 11:51 AM
southpark11235's Avatar
southpark11235 southpark11235 is online now
Mein Auto: 1999 BMW 323is
If you are serious about taking your car up to 200 MPH you will need to do some serious research into downforce. Here is some reading to get you started.
http://superhachi.com/theory/downforce/
http://www.rapid-racer.com/aerodynamics.php
Alex//1999 323is - power e46 M3 seats, style 43 rims, 328 exhaust, Z3 rack, Bilstein PSS coilovers
//1992 Mazda Miata - cat delete, power windows, oil filter relocation
“We got about ten minutes before this entire county is up in flames. If you want to live, you’d better step on the gas! Oh wait is this a Tesla? Sh!t! Well, step on the prissy pedal, we're going to die!” – Cartman
Old 03-13-2013, 01:13 PM
Mr Gusta's Avatar
Fireballs inc.
thanks brah! I think im somewhere around 3k deep already, might end up spending another 1k it adds up quick
Originally Posted by petriej View Post
thanks bro lol nice link
Yea I know that, The ICS yellow m3 that went 223mph in the texas mile last year did so with full undertray and a splitter, nothing else really lol oh and a parachute.
Old 03-13-2013, 01:15 PM
petriej's Avatar
Yea that parachute is critical. Sounds like fun.
Most of the guys in this area just get a liter bike if they want to go that fast. I say, why stop there? Get a small jet. Cheapest way to go is to get your pilot's license and be someone's personal pilot. Not too hard to do in the Bay Area, really.
GGC BMW CCA #443004
Join the BMW CCA!
Old 03-13-2013, 02:17 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
The ol bumblebee went that fast?? That car is insane.
Sent from my SCH-I405 using Bimmer App
-CJ
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
Nice work Frank!
Didn't know you were going bottum mount, I coulda sold you most of my whole kit to save you time.
Turbo Build Here
Old 03-13-2013, 03:40 PM
Mr Gusta's Avatar
Fireballs inc.
apparently the old bumblebee was sold, this is the new honeybee
Originally Posted by FenderBender View Post
Nice work Frank!
I was going top mount, but I couldnt fit an hx40 up top unless I spent heavy money on a manifold, you already pulled your kit off the car?
Just picked my head up from the machine shop! Fresh valvestem seals installed also
paid 180 with the tip
Old 03-13-2013, 03:52 PM
petriej's Avatar
$180 for re-surfaced head and valve stem seals? Did you get a 5 or 7 angle job?
GGC BMW CCA #443004
Join the BMW CCA!
Old 03-13-2013, 03:57 PM
Mr Gusta's Avatar
Fireballs inc.
not sure to be honest, head looks great, he tanked it and cleaned every valve and every valve spring looks real clean, he had to take off 5 thousandths to get it straight, it was real warped, and the motor had no signs to a bad gasket or a warped head, he also pressure checked it and every single one was sealed super tight
cj.surr's Avatar
some kid
That's a hell of deal, isn't it? Maybe I should rebuild the top end of my s52 while it's out.
-CJ
Old 03-13-2013, 04:02 PM
petriej's Avatar
Yea I don't know. That seems way too cheap to me. Oh well, if it fits it sits! Good job.
GGC BMW CCA #443004
Join the BMW CCA!
:3
