E36 (1991 - 1999)
Old 03-29-2013, 12:48 PM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
Hells yeah, Frank. Keep it coming!
1998 BMW 328is
1966 Pontiac GTO
Old 03-29-2013, 03:12 PM
Gooby's Avatar
Gooby Gooby is offline
Sexy Sax Man / Kebab Lord
Mein Auto: 1995 M3
Originally Posted by Mr Gusta View Post
Thanks guys for the tips, randy you are the man, how much are those at the dealer?
Well ECS sells them for $0.99 each. Not sure about the dealer. Most likely wayyyy more lol.
Instagram | @randytheus
Old 03-29-2013, 03:35 PM
Mr Gusta's Avatar
Mr Gusta Mr Gusta is offline
Fireballs inc.
Send a message via AIM to Mr Gusta
Mein Auto: big turbo hellrot sedan
I r ound them for 49 cents each one
Turbo lag is just a headstart because the chase is more exciting than the win - Abraham Lincoln
Old 03-29-2013, 05:19 PM
B_Rad_M3's Avatar
B_Rad_M3 B_Rad_M3 is offline
I6 feels good
Mein Auto: POS
Once you're done! I'll gladly trade you my M3 for your 325i...
Old 03-30-2013, 07:55 AM
Mr Gusta's Avatar
Fireballs inc.
any bigger and it wont fit lol
large hotside for the added exhaust mass of e85
Old 04-05-2013, 01:41 AM
Mr Gusta's Avatar
Fireballs inc.
Motor timed and manifold bolted up, gonna have to figure out something with my wastegate its not going to clear.
Sent from my SPH-L900 using Tapatalk 2
Old 04-05-2013, 07:01 AM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
What's it look like with the flywheel bolted up? Maybe you can modify the bellhousing?
-CJ
Old 04-05-2013, 07:17 AM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
Frank I don't think anyone else has ever mounted a wastegate like that lol.
You'll have to make a runner pipe and located the wastgate further down.
Sent from my SCH-I605 using Bimmer App
Turbo Build Here
Old 04-05-2013, 08:29 AM
jayjaya29's Avatar
jayjaya29 jayjaya29 is offline
Come at ///M3
Send a message via AIM to jayjaya29
Mein Auto: 97 M3
Flip the manifold 180 degrees and run as a top mountttt
Old 04-05-2013, 10:16 AM
Kdoherty's Avatar
Kdoherty Kdoherty is offline
bimmerfest Supporting Member
Mein Auto: A redhead E90
I don't know if you can do that, otherwise I think there'd be a lot more top mount builds. i think the turbo flange sits too close to the valve cover if you flip it.
Originally Posted by Los View Post
^He's been drinking beer and destroying pumpkins with brake rotors and sledge hammers.
So, pretty much just doing man stuff.
  • '06 325xi 6MT
Old 04-05-2013, 10:18 AM
cj.surr's Avatar
some kid
Probably depends on the manifold. They sell a cheap adapter so that you can run stock manifolds upside-down in a top mount setup.
-CJ
Old 04-05-2013, 10:22 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
This. I've seen a few. Pretty clever and 'hobo' style.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 04-05-2013, 10:27 AM
Kdoherty's Avatar
well sheeeit, now that i know that...
  • '06 325xi 6MT
Old 04-05-2013, 10:31 AM
Mr Gusta's Avatar
Fireballs inc.
Yea matt I know I need to run a pipe further down stream or I might run a pipe to the front or even up and dump it out the hood.
Old 04-05-2013, 10:37 AM
cj.surr's Avatar
some kid
for the love of god, no.
-CJ
Old 04-05-2013, 10:38 AM
Kdoherty's Avatar
+1
keep it clean man.
  • '06 325xi 6MT
Old 04-05-2013, 11:19 AM
Mr Gusta's Avatar
Fireballs inc.
Can I dump it out the fender guys?
Old 04-05-2013, 11:23 AM
Kdoherty's Avatar
you could probably make a hole for it i'd be nervous about dumping hot waste gate exhaust on my tires though.
  • '06 325xi 6MT
Old 04-05-2013, 11:30 AM
Mr Gusta's Avatar
Fireballs inc.
I would have it dump behind the tire under my skirt, need to be a showoff.
Old 04-05-2013, 11:32 AM
cj.surr's Avatar
some kid
He'd probably be fine since it would be behind the tires.
Frank, if anyone can make it work, it'd be you. Probably still better off going under the car, though.
-CJ
Old 04-05-2013, 11:35 AM
petriej's Avatar
Pipe it into the heater core. Then you'll get a 'whoosh' inside every time you lift the throttle!
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-14-2013, 04:47 AM
Mr Gusta's Avatar
Fireballs inc.
Motor timed and ready to go, need to make the drain for the turbo, need to make the oil feed and order a few other things.
Sent from my SPH-L900 using Bimmer App
ID:	371345   Click image for larger version
Old 04-15-2013, 08:03 PM
Mr Gusta's Avatar
Fireballs inc.
My stomach hurts
just dropped 720 on parts I need :/
Old 04-15-2013, 08:19 PM
cj.surr's Avatar
some kid
Eek. Should be worth it though, right? Is it all stuff to relocate the wastegate?
-CJ
Old 04-15-2013, 08:30 PM
Mr Gusta's Avatar
Fireballs inc.
nah just the pipe to relocate and dump tube was 30bucks
i bought motor mount arm, poly motor and trans mounts, dssr lever, new style ebay short shifter to test out 66bucks ( i still love my old one), oil feed line and drain as well as oil feed adapter, poly diff bushing, and a few other things.
just goes to show that things do add up and I didnt NEED all of those things but it was smart to do you know.
:3
