Old 08-06-2014, 03:23 PM
A B Able Truck's Avatar
A B Able Truck A B Able Truck is offline
Mein Auto: 2006 550I (N62TU) V8
Originally Posted by bmwmoe View Post
a week ago, and im a daily driver, its holding good so far.
dose it hurt to try?
dosent cost $$$$$
Doesn't hurt to try or experiment especially when it's on someone else's car/expense. So thank you for being the ginny-pig. Please keep us posted on the mileage from time to time. In a week or two (several tanks of fuel) you may want to open her up & see if the diaphragms have deteriorated (please post photos).
The early bird may get the worm, but the second mouse gets the cheese.
Old 08-06-2014, 04:18 PM
new760Liowner new760Liowner is offline
Mein Auto: E66 760, E38 750, E34 540
I'd rather use Viton as an experiment. Unsatisfactory compatibility with gasoline and hydrocarbons doesn't inspire confidence. Hope it works out for you
Old 08-06-2014, 05:15 PM
bmwmoe bmwmoe is offline
Mein Auto: bmw 760li
i took my own risk on my own car trying diffrent diaphragm. and the only thing that lasted so far is EPDM. plus i open one diaphragm up every day to see the condtion, no rips at all... just like when i installed it
Old 08-06-2014, 09:37 PM
nandro nandro is offline
Mein Auto: 760i
Almost every rubber lasts a while. I've tried a lot of stuff. It is important to choose not only the right bottom of the membrane material, but also the size.
Old 08-06-2014, 09:56 PM
Not every rubber lasts. Because I used almost 10 different kinds of rubber. And none of them last .some of them last more then the others. But realy none of them lasts. But the only one the lasts so far is epdm. I been driving for almost 100 miles, so far good.
And about the size you just cut the same size as the hole, where the membrance sites then that circle washer (piston looking) pushes the round rubber so it Can seal it tight
Old 08-07-2014, 05:45 AM
We'd all like to see pics of your three EPDM diaphragm replacement next time you have it opened up for inspection. What thickness of EPDM are you using?
Old 08-07-2014, 09:51 AM
I will post some pics next time.
Woohoo. Finally I just passed emissions.
What does that mean? My 760 dosent have problems. No check engine. She runs A1
Old 08-07-2014, 10:09 AM
The only thing I have to do to the car now, is try to figure out whats making that winning noise in the front of the engine. It sounds like a low power steering fluid! But the reservoir is full and no leacks at all!! I can hesr it on startups and when pushing the throttle only!
What do u guys think?
Old 08-07-2014, 11:22 AM
raymound raymound is offline
Mein Auto: 2004 760Li
it might be s water pump or a belt tensioner bearing...
Old 08-07-2014, 02:00 PM
Thats true the water pump does leack a little coolant when its siting overnight. So maybe the bearing on the water pump is going out. And making that winning noise.
Thanks raymound
Old 08-07-2014, 02:15 PM
Rick in Yuma's Avatar
Rick in Yuma Rick in Yuma is offline
bimmerfest Supporting Member
Mein Auto: 05' 760li,94' H1,08'Smart
While your replacing the water pump . I would replace the tensioner pullies also. Yes water pumps can make noise. Also check your fan clutch. And put new belts on it at the same time. How many miles on your 760 right now?
Old 08-07-2014, 02:22 PM
Yes ebay got a deal on a water pump and all pullies and belt for around $250, not bad?
The car has 84k miles
Old 08-07-2014, 02:45 PM
mws mws is offline
Mein Auto: 760Li, F250 V10, Ex 7.3L
Duetsche parts?
please please PLEASE tell me you did not buy from DP aka Duetsche parts (spelling?). they are crooks and sell really low-quality crap for our cars on Ebay. How do I know? I bought a fan clutch that turned at the wrong RPM (too loud and wound the fan up way too strongly) and also was too short in length, so the fan blades, as they spun so fast they sucked the entire radiator towards them, sawed my hose and left me on the side of the road. total A-holes that would not stand by their product.
if you want the lowest price I am willing to pay for BMW parts, go with
http://www.bmwpartsweb.com
or
http://www.oembimmerparts.com
and I second the part about the tensioners.
1] replace them.
2] but... I have a noise/rotating thing going on the front of my newer motor and replaced all my tensioners and it's still noisy, so that means, the alternator, water pump, or the PS pump is noisy. It can happen.
Old 08-07-2014, 02:59 PM
Thanks for the info mws. sure enough Dp is where I was going to buy the parts from. But thank god u told me so
Old 08-07-2014, 03:29 PM
mws mws is offline
Hey, I did it and I have some experience as a professional mechanic. Live a learn, that's what the forum is for. Stay with actual OEM manufacturers and you'll be fine. Ebay has some deals, but you have to buy the OE manufacturer part from someone who sells them cheap. DP has this crappy knock-off brand called Hamburg Technik (the Ebay ads say HT) and they are just plain crap.
Also avoid at all costs: Febi, Karlyn.
If you use the link for oembimmerparts, you can look up who makes what, and then search for that manufacturer with that part number, on the cheap-- on the web.
Old 08-07-2014, 03:36 PM
hey mws im a little bit lost... do you know where i can buy this new hpfp at a reasonable price?
Old 08-07-2014, 03:47 PM
mws mws is offline
the link was way back on page 2
btw: nr123 mentioned to me he bought one here and they have him a 10% discount, so it was more like $1800.
http://faulknerbmwpartssource.com/pa...=FUEL%20SUPPLY
that link is dead, the new one is
apparently, he emailed them and got an additional 10% off. He paid $1800 US each.
if you want to try to buy a couple of new VW Audi pumps (I found them mostly on Ebay) then the part numbers are just a few pages back. You would then take the diaphragms out and try replacing your old ones with that new part. To the US-- they are about $600 each, shipped, no idea how much money to ship to where you are.
I have not tried that fix, but I would not hesitate to do so, if I had bad pumps. (stay tuned, my car is starting to bump at idle and recently gave me an emissions-related code I have not looked up)
Old 08-08-2014, 10:11 AM
Hey. Anyone tried epdm?. Its holding good so far I been driving on it over 200 miles. With no problems!
Old 08-08-2014, 10:41 AM
You guys asked earlier the thickness of Epdm I used on the hpfp. Its .045" each so thats .045 x 3.
Maybe you can use one of the .090" and one of the .045"
Old 08-08-2014, 11:03 AM
epdm?
Old 08-08-2014, 11:14 AM
mws mws is offline
Pictures of EPDM diaphragms you made, please, and also, where do you source it? Mcmaster Carr?
what part number did you order?
Old 08-08-2014, 11:16 AM
mws mws is offline
Viton
I'm with you on this one. Viton with fiberglass reinforcement might be nice.
Have not looked up the properties of EPDM
Old 08-08-2014, 11:31 AM
mws mws is offline
hmmm, I missed looking back and somehow, completely missed the entire EPDM thing. Just catching up on it now. I must say, it's encouraging. Cutting a sheet of rubber and trying to make my own diaphragms is something I would do in a heartbeat.
but...
wiki:
EPDM exhibits satisfactory compatibility with fireproof hydraulic fluids, ketones, hot and cold water, and alkalis, and unsatisfactory compatibility with most oils, gasoline, kerosene, aromatic and aliphatic hydrocarbons, halogenated solvents and concentrated acids.
Viton on the wiki:
>Viton is generally compatible with hydrocarbons, but incompatible with ketones such as acetone, and organic acids such as acetic acid.
hmmmph, they are opposites. well that's not good.
not so sure about gasoline and possible trace amounts of Ketones. looks like ethanol-blended and high-octane gasoline can have ketones:
http://www.iasj.net/iasj?func=fulltext&aId=21783
googling around brings me to these compatibility charts, there's tons of them.
http://www.customadvanced.com/chemic...nce-chart.html
If I use Acetone as the Ketone and Petroleum for gasoline I get a B for Hypalon (CSM) in both categories. Better than the As and Ds you get for Viton and EPDM on either end of the spectrum for those chemicals.
Old 08-08-2014, 11:37 AM
mws mws is offline
BTW: if you get a material that is thinner than our diaphragms you should still be able to use the current annulus ring to hold the new material down as long as you shim. McMaster Carr sells washers that are many thicknesses and accurate enough to be used as shims. You can mic them out and pick a couple from a batch that will work fine. (just remember to buy stainless )
Old 08-08-2014, 11:42 AM
mws mws is offline
Nandro is it true you used a diaphragm from the Skoda? If so, how do you buy them?
