E34 (1989 - 1995)
Old 03-20-2013, 03:04 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Originally Posted by markfothebeast View Post
I don't know if the CCV is bad, but I would assume so since it appears that someone has put caps over the lines (disconnected it). I don't have enough experience with this vehicle to determine if this is supposed to be capped off or not - But judging from the diagrams I found there is suppose to be a couple vacuum lines running to the CCV. Now, the lower photo shows what looks like another area where a vacuum line is supposed to be connected to the CCV. Am I right or wrong on that?
As for the balloon trick, I put my thumb over the oil dipstick hole and I didn't feel it blowing any air but rather almost sucking in air. However, it appears that the CCV is not even connected. So I don't know what the symptoms would be then.
I'm only going from memory (not personal experience), but I seem to recall that Rick from Ohio determined during his saga with his 540 no-start that one of the ports to the CCV is supposed to be capped off.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-20-2013, 03:08 PM
imae34driver imae34driver is offline
Resident e34 Racer
Mein Auto: 1995 540i SPORT /6 spd
just first thing in my head..
symptom's suggest maybe 1 vacuum line to CCV is capped and vacuum is escaping elsewhere - dip stick???
idk about it myself.. just thinking FYI - one port (driver side on my manifold is blocked off (i believe))
I also bought my car with 200k for 1900$ running smooth with PLENTY of other issue's to sort out! I can't remember if my e38 m60 had the same sound..
**** honda
Old 03-20-2013, 03:24 PM
markfothebeast markfothebeast is offline
Mein Auto: 1995 BMW 540i
Ok. But if there are no lines going to it, should I plug the remaining hole that appears to be allowing a vacuum leak? Suppose I could put my thumb over it and see how it runs.
Old 03-20-2013, 03:52 PM
BMR_LVR's Avatar
Humble E34 lover
Sorry, but I don't know the answer. You may want to send a PM to rv6rick. He is the one that had the no-start on his 540. I think he will be able to tell you which port should have a line on it and where the line should terminate on the other end.
PS: Here is Rick's thread: http://www.bimmerfest.com/forums/sea...rchid=20143505
You can search the thread for "CCV" and you may find your answer in the thread.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
