840csi - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 8 Series - E31 (1989 - 1999)
Old 03-13-2013, 02:22 PM
huntbenz huntbenz is offline
Mein Auto: 840CSI
840csi
I have owned this BMW for a few weeks.It ran good when i first ran it.It has devloped a rought idle.I replaced the valve cover gaskets they were leaking.I have replased the plug wire off the coils And replaced the plugs NGK.Sprayed injectors with carb spray.Seamed that 1 injector had vacume leak.Pulled our injectors and they were all carbon up.So replaced them with rebuilt ones.I still have the rough idel.Off idle it runs great.The check engin light was on and whean i drove it went off.At idle it will go on.Whats up dose any body no what the matter with the idle.I was going to pull of the battery but then i have to get the code from BMW.This car is awsome i love it.
Thanks Rick
Old 03-14-2013, 06:26 AM
02540ico 02540ico is offline
Mein Auto: 1997 850Ci
So, you have a '95 840Ci that has an S70 V12 CSi engine/6spd transplant? Or does it have the factory V8?
Either get a code reader, or take it to Autozone and have the codes read. Otherwise, you'll waste a ton of cash just throwing parts at it.
Have you checked/changed the air filter? Cleaned the MAF?
http://www.bimmerfest.com/forums/image.php?type=sigpic&userid=163865&dateline=1256592405
Old 05-05-2013, 09:25 AM
edes300's Avatar
edes300 edes300 is offline
Mein Auto: 2008 535XI
840csi
I would consider cleaning the MAF and throttle body. Another area in other types of cars that causes problems is the idle air control valve. I'm not sure if this car has one but usually it's connected to the throttle body.
Old 05-18-2013, 03:43 PM
Mein Auto: 840CSI
840 ci
This BMW is one of the best looking of all BMW!
Old 05-18-2013, 03:49 PM
Mein Auto: 840CSI
Miss a idle when first start
The fuel rail had vary small fuel leak.Thank you for your help!
Old 05-31-2013, 10:29 PM
SFbay SFbay is offline
Account Under Review
Mein Auto: BMW 745i
Really?? That was the cause of the bad idling??? 99% it's intake vacuum leak, it gets unmetered air therefore engine runs lean but O2 sensors make it run rich to compensate.
