E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
Tried the NOID!
So a little history. Bought a 85 e30 not running. Found that it will start with starting fluid. replaced all fuel lines and filters and pumps. Getting 40 lbs pressure at rail. Used a generic Noid light from Autozone. getting no light. (Although my son and I tested the ohms and he swears it was getting 2 ohms.) So this means the brain or ECU is dead right? Or is it the Ecm? Big difference in price. Can someone let me know please. I dont want to have to junk this car.
have you checked the crank sensor?
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming |
Not yet. Got a used Ecu and now I get light flashes at the injectors but I think the injectors are clogged. no fuel out the bottom. Getting 37 psi at the rail. Will the crank sensor dictate when the injectors operate?
The crank sensor times everything. Ignition, injector pulses. If it's bad, the ECU can't fire anything on time.
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
This would be down by the transmission or am I thinking of the CPS?
Crank position sensor and the engine speed sensor are located on the bellhousing behind the starter mount. If either are bad the engine will run very poorly if at all.
Have the injectors cleaned, or source another set as this may be the problem.
m |
There's a guy on this board that cleans injectors. Search for 'MEPEH'.
Yeah i been PMing him. he wont have any til Sunday which means they are about 4-5 days away still. Im getting some from a junkyard today to see if that is the problem.
He's about two miles from where I work. Let me know if I can assist.
I appreciate it.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
