Power steering fluid level: please help! - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series
3 Series & 4 Series
The BMW 3 Series and 4 Series Forum. If you would like to see all new posts in all the forums, click here.
Old 05-15-2002, 10:33 PM
JuanCarlos JuanCarlos is offline
Mein Auto:
Hey guys, I finally found the cause of the leak on my car: it was a bur on the housing, which prevented the gasket on the cap to seal properly. The fluid was probably leaking since day one, and there was fluid all over the darn engine.
Anyway, the cap has 2 indicators, and the manual doesn't say anything about checking power steering fluid. I need to know if the 2 indicators are LOW/HIGH, or COLD/HOT. The fluid is at the bottom line now, so I'm assuming it's the LOW point, since so much fluid leaked out. There's always a chance it's the COLD mark (it's ATF fluid after all, and it expands as it heats), and I would overfill it if filled to the second mark.
Your help is appreciated.
JC
'00 323CiC silver/black/tanin SP PP CD Manual
Old 05-16-2002, 03:08 PM
Mein Auto:
Nobody with a service manual?
Could somebody just check the fluid level in your car? I assume all BMWs have the same thingie on the cap.
Thanks guys!
Similar Threads
This Is The Official Hijack Thread... Sabrina Off-Topic 146 05-21-2009 07:38 PM
Power steering fluid level check. How to? fpa1974 E36/7 Z3 (1996-2002) 6 07-07-2003 06:15 PM
t Nick T. The Test Board 5 07-05-2003 10:25 AM
Power Steering Fluid Level ? 3LOU5 3 Series & 4 Series 5 12-11-2002 12:25 AM
