E34 (1989 - 1995)
Old 03-14-2013, 10:58 AM
Gehrke33 Gehrke33 is offline
Mein Auto: 94 bmw 525i
94 bmw 525i dme problems
Hi guys I am new to this site, I have a 94 bmw 525i and I was wondering if I could put a used dme in the car. I have heard conflicting reports on this. Any insight you could offer would be appreciated. Thanks
Matt
Old 03-14-2013, 11:12 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is online now
Humble E34 lover
Mein Auto: 1992 525i
You can use a used red label DME ending in 413. It is for vanos M50 engines which you have. You do not have EWS II, so you don't have to worry about that.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-14-2013, 11:41 AM
thanks a lot steve, i will get a used one and give it a wirl.
Old 03-14-2013, 12:08 PM
do i need to swap the chip from my old one to my new one?
Old 03-14-2013, 12:20 PM
BMR_LVR's Avatar
Humble E34 lover
Not unless you have an aftermarket chip or a chip that has been mapped with increased performance parameters. If you are stock, just swap the DME.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-14-2013, 12:22 PM
great thanks
Old 03-14-2013, 12:44 PM
BMR_LVR's Avatar
Humble E34 lover
My pleasure. Please report back to let us know if it fixes your problem.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-14-2013, 04:56 PM
i'll let you know, thanks
Old 03-15-2013, 07:18 PM
I put a new computer in the car and still no start, is there something I am missing or donthibg else I should try. The dme came out of a 95 325i, it's a red label and the numbers match. It was a running car that was rolled. Any suggestions?
Old 03-15-2013, 07:38 PM
BMR_LVR's Avatar
Humble E34 lover
Give some history on the no start situation.
What have you checked and how did you check it?
Most common causes are bad CPS, fp fuse, fp relay, fp, main relay.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-15-2013, 08:13 PM
BMR_LVR's Avatar
Humble E34 lover
Do you have the Bentley manual? It has a very good trouble shooting guide. Here is a searchable version.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-16-2013, 09:10 AM
no i dont have a bently manual, i guess i should get one.
Old 03-16-2013, 09:13 AM
BMR_LVR's Avatar
Humble E34 lover
Click on the link (the word "here") in my post above and you can download a searchable version.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-16-2013, 09:49 AM
Great, thanks
Old 03-17-2013, 09:27 PM
i bought the car about 2 weeks ago and was told it had a bad fuel pump but upon further investigation i found the fuel pump was fine so i started doing some trouble shooting. I dont have a lot of experience with the e34 my other bmw's were 87's and didnt have many problems. I am a mechanic but decided to give it to a shop because i thought it would be easier to just have sombody else trouble shoot it. the shop told me it had a bad dme so i got a used one out of a running 95 325i. It is a red label with matching numbers and works fine but the shop hooked it up said nothing changed. Still doing the same thing, the shop is telling me i need the chip out of my old computer to put in the replacement? Dont know if thats true, I am not really sure were to go from here. I have checked the fuel pump and it works and is giving proper fuel pressure, I checked the fuse and there is no power at the fuse, I can jumper the relay and the fuel pump kicks on but not when i turn the key on. The relay is good but i bought a new one anyway and no go still. The coils have correct voltage and i have spark but the injectors are not working, dont know if the fuel pressure effects the injectors. i have not checked the CPS but the shop didnt have any codes for the CPS. I havent replaced the CPS but i am considering doing it anyways. It will fire on starting fluid but i am really stumped here, any ideas?
Old 03-18-2013, 06:14 AM
drew528i drew528i is offline
Mein Auto: 528i
Not shure if bmw has inerta safety swich but shoul have one. if car was rolled then it should have dissabled the fuel pump and could have dissabled the injectors too
Old 03-18-2013, 07:20 AM
BMR_LVR's Avatar
Humble E34 lover
You do not have to change the chip from the old red label 413 DME to the "new" red label 413 DME unless you had a performance chip in there. It will run fine with the stock tune of the "new" DME.
Don't forget to check your main/DME relay. The main/DME relay supplies power to the FP fuse. If the FP fuse it not getting power, this is likely be the problem.
How did you confirm spark?
Check the resistance of the CPS. Note: The Bentley had a misprint on the readings. It should be 540 +/- 10%, NOT 1280 as listed.
You say the engine will fire with starting fluid. Does it run (albeit you should only run it for a few seconds) or just cough and act like it is trying to fire? You can actually keep a car running on the starting fluid if you continue to squirt it in there, but again, you should not run it for more than a few seconds. If you can keep the car running on starting fluid, then you have ruled out a problem with spark and it is purely a fuel delivery problem.
Your situation sounds a lot like this one: http://www.bimmerfest.com/forums/sho...d.php?t=678449
If you replaced (or disconnected) the fuel pump, make sure that you didn't accidentally get the fuel lines crossed.
Keep plugging away at this and you will get it sorted out. I suspect the main/DME relay most.
Let us know how it turns out.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-18-2013, 01:38 PM
i just got my car back from the shop and tested my cps, the meter is giving me no reading through the cps. I believe i am testing it right, im testing the resistance between proings 1 and 2 and my meter is just reading an open circuit. I already ordered a new cps should be here today still. let me know if you have any thoughts about not getting any reading through the cps, thanks
Old 03-18-2013, 01:48 PM
BMR_LVR's Avatar
Humble E34 lover
It sounds like you tested it properly. An open circuit would indicate a failed CPS. Didn't your mechanic check this for you? Did he give you a non-running car back? Let us know how it goes with the new CPS.
Keep us updated
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-18-2013, 02:11 PM
the mechanic did not test the cps he was hung up on it being a bad dme and said i had to change the chips, it wasnt optional so i just went and got my car back. I am using a red label out of a 95 325i and he said they werent compatable. his diagnosis was a bad dme and the one i got him was not the right one so he wanted me to get another one. i would rather do it myself and not deal with mechanics ego's.
Old 03-18-2013, 02:24 PM
BMR_LVR's Avatar
Humble E34 lover
I agree completely with you. If your car had the red label 413 DME in it initially, then another red label 413 DME will work without any problem (assuming of course that the second DME is good, but as you said, you got it from a running car).
I think you are on the right track with the CPS. It is a VERY common failure item and one of the top two or three reasons for no-starts on our beloved E34s.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-18-2013, 05:49 PM
changed the cps AND IT RUNS!!! runs really rough though almost cant keep it running. if you get it over 2000 rpms it smooths out but it is really difficult to keep running at low rpms, almost no throttle response. any ideas?
Old 03-18-2013, 06:01 PM
BMR_LVR's Avatar
Humble E34 lover
Hmmm ..... not sure.
I would do the stomp test to see if there are any error codes.
Have you disconnected the throttle position sensor during this problem? Have you disconnected anything else? Double check your electrical connections.
You can try putting the old DME in there as well.
Keep at it. I believe you will get this figured out.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-18-2013, 07:57 PM
FINALLY!! i got it running right, i took it to the gas station and put fresh gas in it and it runs like a top. still surges at idle a little bit but i think its just the TPS, no biggie. thanks for all your help, i really appreciate it. Turns out it was just a Crank Position Sensor and some fresh gas after all. THANKS AGAIN
Old 03-18-2013, 08:01 PM
DanM5's Avatar
DanM5 DanM5 is offline
My other ride is ur wife
Mein Auto: 535is-m
Get in, sit down, hang on, shut up!!
94 525i, bad dme, dme replacement
