Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 03-14-2013, 11:19 AM
vnamvet vnamvet is offline
Mein Auto: 1987 325i
'87 new buy maintenance checklist
Looking forward to recieving a '87 vert this weekend. Even though the previous owner was good on his maintenance, I plan on immediately doing the following:
Timing Belt kit....not changed in several years (30k miles ago)
change auto trans fluid and filter
change rear end fluid
brake fluid flush
What would be some other suggested items to address?
I used to have a 86 325e coupe way back in the day so I'm somewhat familiar with the layout and some of the issues.
Old 03-14-2013, 11:24 AM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
some more i would suggest:
thermostat
water pump
spark plugs
distributor cap & rotor
fuel lines
check for misc leaks
that's all i can think of right now
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 03-14-2013, 11:51 AM
Thanks....good suggestions. I was planning on the fuel filter also......I noticed you suggested fuel lines. Are the fuel lines difficult to replace?.....I'm no spring chicken...
Old 03-14-2013, 02:01 PM
fcsteve's Avatar
610EUROs
fuel filter is another one.
the rubber fuel lines are not hard to replace. i would leave the metal ones alone as long as they don't have any serious rust on them.
Old 03-14-2013, 03:32 PM
Thanks for the input....now what on-line source would you recommend for quality parts at a reasonable price?
Old 03-14-2013, 05:49 PM
fcsteve's Avatar
610EUROs
i prefer Pelican Parts.
some other mermbers use different places, but most of them are more expensive than Pelican.
Old 03-14-2013, 06:38 PM
First time's Avatar
First time First time is offline
INSANELY UNPREDICTABLE!
Mein Auto: 1984 318i
^ this
