E34 (1989 - 1995)
Old 03-14-2013, 12:05 PM
e34crank e34crank is offline
Mein Auto: 90 535I,89 735il
E34 brake light priblems fuse 1
I will put a new fuse #1 in and I can drive around use the brakes all I want but if I come to a complete stop it will blow the fuse. If I slow down with the brakes and use the e brake to completely stop it doesn't blow. Any suggestions would be greatly appreciated
E34 535i
Old 03-14-2013, 10:29 PM
Not everybody at once
E34 535i
Old 03-18-2013, 11:49 AM
Help
E34 535i
Old 03-18-2013, 12:07 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
I wish I could help, but electronics is my weakest point
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-19-2013, 12:49 PM
Alnlesley Alnlesley is offline
Mein Auto: 91'bmw ac schnitzer
Are you using the proper fuse rated for the brake lights.
Old 03-19-2013, 01:30 PM
I've tried every fuse there is. Could it be a break wear sensor or my abs relay?
E34 535i
Old 03-19-2013, 01:40 PM
I am not sure i it could be ur abs but have u changed any of ur brake light lately? Could be wrong bulb or connection problem..
Old 03-19-2013, 02:01 PM
So I was dd one night and a few more people tagged along in the trunk idk if they messed with my third break light or something I'll take it out and see what happens.
E34 535i
Old 03-19-2013, 05:12 PM
Ya that wasn't it I got some abs relays laying around I think I'll try that. Probably a short somewhere in the wiring but I can't find it and IM in denial
E34 535i
Old 05-02-2013, 04:25 PM
Jay. Jay. is offline
Mein Auto: E34
iM HAVING THE SAME ISSUE WITH 90 525. pLEASE LET ME KNOW WHAT THE PROBLEM WAS.
Old 05-02-2013, 08:32 PM
MySatinDoll MySatinDoll is offline
I'm from NJ. So What!?!
Mein Auto: What they Drive
You have a short somewhere.
Check the common ground on the rear left passenger bulkhead below the rear bench cushion (not under it but on the outside of that compartment under the carpet.)
If those brown lines have a bit of green on them clean them up and resecure to the bulkhead.
_______________________________________
Content Writer - FCPEURO
95 e34 525 5 spd S52 Swap...Sold
01 e38 740i msport (under restoration )
Old 05-13-2013, 12:56 AM
Mein Auto: 1989 525i M20B25
Remove and replace all the bulbs, maybe you will find something in there that shouldn't be there.
After you have ruled out a short in the bulbs or wiring, start looking at the brake light switch.
