The X5 SAV Forum
Old 03-23-2013, 03:07 PM
stevepage7 stevepage7 is offline
Mein Auto: 2001 BMW x5
aftermarket stereo
I have a 2001 x5 with a OEM stereo fitted (satnav/TV) I want to fit a new stereo but the connections at the back x 2 are only small all the harnesses ive seen are for standard fittings - is there anywhere i can get connectors to fit an aftermarket stereo
ID:	367765   Click image for larger version
ID:	367766   Click image for larger version
Old 03-25-2013, 10:56 AM
That is just the screen, the "Real Radio" is located in the trunk area in front of the battery under the plastic that has BMW embossed on it.
Old 03-25-2013, 12:36 PM
aftermarket stereo
can I get connectors or a harness to fit a aftermarket stereo
Old 03-25-2013, 09:54 PM
Crutchfield.com could answer that question for you. It depends on what head unit you will be buying for your X. There are some headunits made specifically for the X and it's very much plug and play. You should post your question at xoutpost.com.
Here's a thread at xoutpost on the Chinese radio for the X.
http://www.xoutpost.com/bmw-sav-foru...ingan-nav.html
