BMW E60 does not recognise the CD changer - Bimmerfest - BMW Forums
Old 03-15-2013, 04:33 AM
Artan Artan is offline
Mein Auto: BMW E60 2004
Hi, my BMW E60 year 2004 does not recognise the CD changer (the one with 6 CD's). After I select a CD option this message appears in the screen "No supported and readable audio medium found in either internal drive". I disconnected the CD changer in the trunk and reconnected and I could hear the sound when reading and switching the CD's and still doesn't work. However, the single CD drive which is in the front (just below the screen) works. Did anyone have similar problem? Please advice
Old 03-15-2013, 05:08 AM
wcr3d wcr3d is offline
Mein Auto: 2013 535iX M Sport
If you're adding the changer it has to be coded also.
Old 05-19-2013, 07:14 AM
Mooreyboy Mooreyboy is offline
Mein Auto: 535D Touring
CD Changer
My CD changer has exactly the same problem and I see from a reply that it has to be coded. How do you code it?? (I will try U tube!)
Old 05-19-2013, 06:29 PM
FreeHomes FreeHomes is offline
Mein Auto: 5 Series
Eject cartridge not working
I have 2005 545 with CD in glove box, but green eject cartridge isn't working, any ideas would be appreciated.
Thanks,
Old 05-19-2013, 06:39 PM
There is a coding section in this forum or you can look over at bmwcoding.com
Old 05-19-2013, 06:44 PM
Thanks,
I haven't seen a green cartridge. Do you hear it cycling when it powers up?
Old 05-20-2013, 01:45 AM
My 535 has the cartridge in the glove compartment how difficult is it to check the wiring
Old 05-20-2013, 01:57 AM
Not very difficult. There are two small doors on the sides that cover screws that extend and retract catches for the mounting. Then should only be two plugs for connection.
Old 05-20-2013, 02:11 AM
thanks will try-saw the little doors but thought there would be a special BMW tool to opertate the screws!
Old 06-18-2014, 05:25 AM
mariosoliman911 mariosoliman911 is offline
Mein Auto: 2005 Bmw e60 530
i have a similar problem on my bmw 530 e60 2005, the cd changer cycles yet cd's dont show up on idrive and nothing plays even, dealer said its the control module !!!! plpease help meeeee !
Old 06-18-2014, 08:03 AM
It needs re coding-and I am afraid there is nothing that an amateur can do and BMW dealers will not do it unless it was an original part-mine came from ebay. A specialist BMW garage will do it though-it is not difficult and they should not charge very much. in the end cheaper than buying a new one!
j
Old 06-18-2014, 10:59 AM
What causes it to need re-coding ?
Old 06-18-2014, 02:13 PM
because that is how they try to stop radios being stolen.
bmw e60 cd changer problem
