E90/E91/E92/E93 (2006 - 2013)
Old 03-15-2013, 05:17 AM
drboomer drboomer is offline
Mein Auto: 2011 328i xDrive
Spare Tire
I was told by the dealer that I have a type of tire that will not go flat for ~50 miles, that's why I don't have a spare. Should I invest on getting a spare? I never heard of these type of tires before.
Old 03-15-2013, 05:24 AM
Last Sight's Avatar
Last Sight Last Sight is offline
Mein Auto: 09 328xi E92 6MT "BLTxi"
They're called Run Flat Tires or commonly referred to as RFTs on this forum. You can read more here:
http://www.tirerack.com/tires/tirete....jsp?techid=56
A lot of forum members get rid of their RFTs due to the harshness in the ride that they cause. Not everyone picks up a spare but if you do there is a sticky on this forum about it.
09 328xi 6MT: Montego Blue Metallic, Saddle Brown Dakota Leather, wood trim, iDrive, Sport Pkg, Cold Pkg, Premium Pkg
Previous Rides:
'11 Ford Fusion SEL
'08 Honda Accord Coupe
'01 Saab 9-3 2.0T
Old 03-15-2013, 05:35 AM
Do you suggest I get different tires down the road?
Old 03-15-2013, 05:39 AM
Last Sight's Avatar
It's up to you, I haven't switched so I can't really comment on the difference. I would search "Pothole explosions" for a thread that had a bunch of people's experiences with both types. I'm sure someone else will chime in with their experience switching.
Previous Rides:
'11 Ford Fusion SEL
'01 Saab 9-3 2.0T
Old 03-15-2013, 05:48 AM
furby076's Avatar
furby076 furby076 is online now
IntarWeb Stalker
Mein Auto: 2013 335xi M-Sport
I used RFTs for my car and they were handy when I had flats. Some things to note:
1) If you get a nail on the portion of the tire that touches the ground, as long as you didn't ride the tire empty you can get it repaired at a shop with a plug. I did this on two tires and drove them just fine for many miles
2) You may want to buy a couple of spares and keep them in your garage. You can get them online for fairly cheap. Great way to save money. Then if you ever get a flat that requires replacement you have the tire, and don't need to pay dealership over inflated prices.
3) BMW tires tend to lose air on a regular basis. I got a portable air pump and keep it in my trunk. Then if the tire is ever low I can fill it up where I am at. These devices can go from $20-$100. The $20 ones are just fine
"Booberry" -ED 2013 335xi | B45 | ZMM | ZDA |Heated Seats | HK |EBII
My Drive Style
Because I can.
Originally Posted by cwinter View Post
I agree with furby
Originally Posted by guerilla twang View Post
Hahahaha, I like you furb, you like to live dangerously.
Originally Posted by ProfessorCook View Post
I started to google to find a picture to match furby's suggestion to Gia, but it quickly became clear it was an inappropriate search to conduct at work.
Old 03-15-2013, 06:15 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Mein Auto: 2009 335i xDrive coupe
You should also note that if you drive it with no air in it for 50 miles or so, the tire is toast and needs to be replaced. If you refill it with air when you get the alarm and if it is a slow leak, you can get it fixed, within the constraints on damage location that Furby notes above.
I got a spare for mine, even when it had run flats (now has non-RFT tires). Many people just go with the compressor noted by Furby or carry nothing extra at all.
2009 335i xDrive coupe, Jet Black, Black Leather, Grey Poplar, Steptronic, ZPP, ZSP, ZCW, iPod/USB, HD radio, Parking Assist. Rear Fogs, Hardwire V1, ProFit G3.
ED May 12, 2009, Munich dropoff May 16, Redelivery June 22, 2009
Prior 33 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette (kept until first Bronco) / 1981 Subaru GL wagon AWD / 1983 s10 Blazer 4x4 (big mistake) / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion
Old 03-15-2013, 07:04 AM
bimmerzone's Avatar
bimmerzone bimmerzone is offline
Supporting Vendor
Mein Auto: E63 650i
The run flat & non-run flat debate has been going on for a while. In general, we can sum it this way. Run flats are good because it usually does not go flat right away, thus allowing you some time to get to a spot to change it, but the longer you drive on it, the tire slowly gets chewed up and you would need a new tire.
If you have conventional tires, you wont be able to drive it after a puncture, but assuming you have a spare tire on hand, you swap it out and fix the damaged tire, usually at a much lower cost. the conventional tires also drive much better, you can read up a bit on the spare tire if you do decide to get one for your E90+ : http://www.bimmerzone.com/BMW_Perfor...T-E90-KIT.html
| Bimmerzone.com | 1-800-357-7797 | info@bimmerzone.com | 833 Lincoln Ave, Suite 5, West Chester PA 19380 |
Video about Bimmerzone: http://www.youtube.com/watch?v=me5pjPS88Bw
We are proud to be Authorized Dealers for: Sprint Booster, Peake Research, Eisenmann Exhaust, Hartge, RPI Exhaust, AutoEnginuity, Bentley Publishers, Zymol, P21S, PowerFlex USA, Brembo GT, KW, Hawk and much more!!
Old 03-15-2013, 07:07 AM
SwissCheeseHead SwissCheeseHead is offline
Mein Auto: 08 G37,94 530i,11 328iT
^ $300 for a spare and a jack that should be included with the vehicle is a joke. Sorry, but I had to. What were the engineers thinking? Anyway, I digress....
2008 Infiniti G37, 1994 BMW 530i, 2011 BMW 328iT
Old 03-15-2013, 07:23 AM
Hound Passer's Avatar
Hound Passer Hound Passer is offline
Mein Auto: 335i Convertible
The RFTs work as advertised...about the only good thing about them (personal experience w/ a flat). So, unless you decide to ditch RFTs for driving reasons, I wouldn't bother w/ a traditional spare. It's just going to eat up trunk space if you keep it w/ you. If your tire light goes off don't go over 50 mph though, slower is better where possible.
ED P/U: 5/31/11
On Cargo Ship "Elektra": 6/15/11
Somewhere in NJ: 6/29/11
Redelivery: 7/14/11
Old 03-15-2013, 07:44 AM
Thanks for all the info. I never even heard of RFT before I got this car. Just picked it up yesterday. I do agree that a spare should be included but, oh well. Cant do much about it now. Not going to turn away the car over a spare tire. What about a can of fix a flat, I know that ruins the tire if you use it but is that something to consider besides an air compressor?
Old 03-15-2013, 08:15 AM
Mark K's Avatar
Mark K Mark K is offline
Mein Auto: 2011 E92 335i MT
RFTs work as advertised ONLY when you have a flat, and even then not 100% of the time (slash or rupture in the sidewall). The rest of the time (100% for most of people) they just suck so bad to take the joy of ownership away from you. Of course, people are different and as such have very different priorities and parameters to judge anything. But I am for sure not alone to think it that way.
Old 03-15-2013, 08:18 AM
Mark K's Avatar
Somebody posted a link above, you can get a donut spare for E9x BMW. I have it and use it only for road trips (one in more than a year since I changed to normal tires). For running around the town (so to say), I have a compressor and glue in the package and if that fails, tow truck.
The only problem is that when you need a space for luggage (road trip), then you need a spare tire as well.
Old 03-15-2013, 08:22 AM
Zooks527's Avatar
Current Fix-A-Flat systems can be compatible with both the tires and the pressure sensors. Many systems, including the BMW "Mobility Kit", include a bottle of sealant and a mini-compressor. There are people who carry it as an option.
YMMV.
Old 03-15-2013, 08:52 AM
furby076's Avatar
IntarWeb Stalker
The jarring ride is not just the RFT but the tight as hell suspension. Once you get used to it / expect it, then it is not a big deal.
I enjoy every moment of ownership from my BMW except when I have to pay to repair it.
My Drive Style
Because I can.
I agree with furby
Old 03-15-2013, 09:29 AM
cwinter's Avatar
cwinter cwinter is offline
Here comes trouble!
Mein Auto: 2009 328i E90 :)
That's not a proper assessment:
1) Since the car has run flats, a spare and jack are not necessary to include. It'd be nice (and the 5-er for example did have it included), but saying it should have to be included isn't right.
2) The $300 you might chalk up as a loss were given to you in the form of a more expensive tire. RFTs can easily run twice the cost of a comparable GFT tire.
I might go back to the RFTs since I can get an A/S now on my wheel setup. The spare would only come with me if I travel outside of my home area. I have been satisfied both the GFT I had on the care and the RFT it came with. Had an A/S been available when I replaced tires, I likely would have never gotten the spare and ditched the RFTs.
2009 328i Sedan - Ordered: 2/24/09 .:. Delivered: 5/6/09
Jet Black | Black Dakota | Aluminum | Premium | Sport | Xenon | CA | Split Fold Seats
You will rue this day, RUE THIS DAY
Old 03-15-2013, 10:35 AM
ptrcd003 ptrcd003 is offline
Mein Auto: 328i
How exactly do "BMW tires" differ from other tires? And what brand are "BMW tires"?
Old 03-15-2013, 10:43 AM
85dave305 85dave305 is offline
Location: fort stewart ga but born and raised in Miami FL
Mein Auto: 00 540i Msport & 06 325i
if you shop around locally im sure you can find a spare and a jack for a lot less. thats what i did for my wifes e90 and she still has the rft
Old 03-15-2013, 01:01 PM
Pilgrim Pilgrim is offline
Mein Auto: 2009 328iX Coupe
The first and most important thing for you to do is to READ the owner's manual. All of it. No offense, but if you had reviewed it you would not have had to ask....and there are tons of other, much more technical details that this car requires you to understand.
Personally, I have no problem with the run flat tires, and neither does my wife. We do have the Continental tires, which are reputed to be a more pleasant ride than the original tires.
1983 Datsun 280ZX Turbo
2009 BMW 328iX Coupe
2007 Nissan Murano
Old 03-15-2013, 01:05 PM
bimmerzone's Avatar
Supporting Vendor
Mein Auto: E63 650i
In the end, do your research and see what you are comfortable with, some people prefer fun flats, some people prefer non run flats with a spare, Its not going to be a one size fits all solution
