Strange Brake Issue - Bimmerfest - BMW Forums
Old 03-16-2013, 12:59 PM
235301 235301 is offline
Mein Auto: 06 525xi Monaco Blue
Strange Brake Issue
I had my front brakes redone about 4 months ago. After it was done I noticed an odor through the that came through the vents after heaving braking. At first I was willing to allow it for awhile since I figured it was burning off the new brakes. However, it has persisted. I took it in to the indy that did the brake job and they claimed there were no leaks in the brake system.
The odd thing is the smell is only there on heavy braking say coming off the highway after awhile of driving. And, here's the odd part, it's much more prevalent if there is a left hand turn after coming off the highway. So I have to believe something is leaking. And it's winter here so it's hard to tell if there is anything on the garage floor with all the melting snow/ice that comes off the car when you park it in the garage.
The odor is kind of a burnt petroleum type of smell. Thoughts?
Old 03-16-2013, 07:11 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
Since it was done at an independent mechanic, I'm sure they put some grease in an area where it's not supposed to go. Not everyone can do brakes, even some guys with the ASE cert. in that area (I've seen one). The brakes should have been broken in by the tech already so any burning smell should have been worn off by you after a few stops. If nothing is leaking by way of pushing the pedal hard while parked at home, (pedal doesn't go to the floor) then it's probably a grease issue. A few issues from doing brakes incorrectly: You can strip the brake line while trying to put it back on, you can hang the caliper (with pads sometimes) by the brake line causing unnecessary stress on the line, or you could put the caliper back on with a wrong twist left or right causing the line to have an unknown kink leading to a leak.
You may have to go elsewhere to get the job verified. If they find something wrong, get it in writing then take it back to the other shop to have them pay/refund, then do business with them no more.
Old 03-16-2013, 07:54 PM
pjinca pjinca is offline
USAF Pararescue Veteran
Mein Auto: 2008 550i
I'd bet money they didn't clean the rotors before installing them. All replacement rotors have a thing coat of oil on them to avoid rust during shipping and storage. This must be cleaned off with brake parts cleaner prior to install. Also, proper bed in is required
Sent from my SGH-T989 using Bimmer App
2014 535i - MSport, HUD, NAV, Prem, Surround View, Driver Assist
2008 550i (R.I.P.)
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
