Old 03-16-2013, 03:44 PM
Pittwm Pittwm is offline
Mein Auto: 2011 X5
Any solution to hard downshifting when rolling to a stop
My 2011 just reached 12k miles and the trans is downshifting hard when I roll to a stop, it also happens when I give a bit of gas and let go when I roll start from a deadstop. Local dealer was nice enough to had reprogram at their own dime since the car didn't have any fault code. The "Clunk" is definately felt everyday and by the tech at the dealer. Anyone has this issue and gotten a fix correctly from the dealer?
Thanks for any input!
Old 03-16-2013, 04:05 PM
RockChips RockChips is offline
Mein Auto: 2008 X5 3.0si
So did the reprogram fix it?
There was a similar known issue on early e70s
Old 03-16-2013, 04:46 PM
Mein Auto: 2011 X5
Nope... It's still there.
What were the solution on the early ones?
Old 03-16-2013, 07:32 PM
blue dragon blue dragon is offline
Mein Auto: X5 35D
Try doing a tranny adaptation reset
'09 X5 35D - Work horse
'17 X1 MSport - Wife
'17 340i MSport (ordered) - Soon to be daily
Old 03-16-2013, 07:38 PM
z51vette z51vette is offline
Mein Auto: 13 X5 50i M-Performance
do you have a 5.0?
is there an rpm spike as well?
Old 03-16-2013, 08:09 PM
ard ard is offline
Resident Curmudgeon
And do keep in mind that your warranty booklet does not say "BMW will repair any defect that has a code"...they are on the hook to fix problems code or no code, your dealer is lazy. IMO
Old 03-16-2013, 08:12 PM
Mein Auto: 2011 X5
The trans reset was the first thing the dealer did but didn't work so they proceed to reprogram.
My is a X35.
My googlefu is weak and all I found are problems associate with early gen X5s trans problem.
Old 03-16-2013, 10:38 PM
Mein Auto: 2011 X5
This is the seventh X5 we have had... It's the worst one. So far, passenger mirror been replaced, then it's the door panel got messed up in the process. The blower motor was recently repl bc of unpleasant screeching noise. The engine fan been repl for the second time... Now it's this trans problem...
Prob our last X5.
Old 03-19-2013, 09:05 AM
ccote3 ccote3 is offline
ccote3
Mein Auto: 2008 X5 4.8i
I just picked up a 2008 4.8i and have the same downshifting issue. There is an rpm spike and the only way to resolve it is to down shift manually into first just before you stop. Any further feedback is greatly appreciated.
Old 03-19-2013, 09:10 AM
Mein Auto: 2011 X5
Mine is going back to the dealer thurs. I'm thinking this is mechanical maybe fluid related. It only doesn't it after the car is driven a few miles... On the plus side, since the reflashed, my MPG has increased almost by 1 mpg. Figure that.
Old 03-23-2013, 09:47 AM
Mein Auto: 2011 X5
Car went back to dealer Thursday, they check trans oil and its a pint low. Filled it but apparently it didn't solve the issue. It's still at dealer over the weekend maybe til Tuesday the earliest. The high note is that my loaner is a 2013 740i M pkg.
Old 03-23-2013, 04:07 PM
ccote3
transmission downshift thump at a full stop
i can the transmission reflashed the other day. It didnt help. I did notice one thing. The shop forman at BMW said that if the floor mat pushes against the gas pedal, the transmission thinks you will attempt a rolling start so it downshifts roughly. I did notice that when i brake, I usually lift off the brake slightly before it reaches a complete stop (like most good drivers) to prevent the suspension form giving you whiplash. Every time I did that, the car almost anticipated that I would be hitting the gas a downshifted roughly. If I dont lift off the pedal or keep the car in manual mode, it doesn't thump??? Seems like a programming issue to me. Not sure how to accomplish it. will look into it further.
Old 03-23-2013, 04:16 PM
sunny5280 sunny5280 is offline
Mein Auto: 2011 X5-M
This appears to be similar to issues experienced with the E53 X5. Doesn't appear there was ever a conclusive cause / resolution to the problem.
Old 03-23-2013, 06:47 PM
Mein Auto: 2011 X5
That's interesting.... I use the fitted weather tech tray so I'm pretty sure it not slidin forward to affect the gas pedal.... Idk what's next to try.
Old 03-27-2013, 05:18 PM
Mein Auto: 2011 X5
Update... Still not resolved. Dealer now say they will open a Puma case.... What's next guys? Puma always seems to me a nice way to say you are screwed and we have no clue how to fix it.
Old 03-27-2013, 06:33 PM
Did this happen since new, or did it arise later?
And if it arose later, what event occurred right before?
Old 03-27-2013, 07:24 PM
Mein Auto: 2011 X5
This hard downshift started prob a month or so back.... Nothing really happened that led up to it.
Mein Auto: 2011 X5
I take it back, I got a new set of Michellins....
Old 04-01-2013, 09:06 PM
Mein Auto: 2011 X5
I noticed something else about this problem... When I stop at an intersection and wait to make a hard left (ie, turning into a driveway while wsiting for the on coming traffic), the car drivetrain feels like its grinding (I'm lack a more descriptive word here).
Also, the outer edge of my new left front tires are feathering and one end of each outer treadblock is chewed up pretty badly (I had an alignment in Jan when I got my tires put on). I think its not just a transmission problem but something with the xDrive.
Old 04-02-2013, 02:20 PM
Mein Auto: 2011 X5
I think the front a differential is faulty... And it's temp related.
Old 04-02-2013, 02:26 PM
post your wheel alignment sheet
Old 04-02-2013, 02:56 PM
Mein Auto: 2011 X5
I never gotten a sheet but this is my left front tire
http://smg.photobucket.com/albums/v2...ps8207d8bc.jpg
Everytime I made a hard left, the front end feels its "slipping"...
Old 04-03-2013, 03:08 PM
Mein Auto: 2011 X5
I hate to sound like a whinny asshole but this is absolutely the last one we are getting both for business lease and personal purchase.
Old 04-11-2013, 04:10 PM
Mein Auto: 2011 X5
Update... Brought the car in yesterday, they pinned it down to a transfer case problem... Waiting to see what the fix is.
Old 04-12-2013, 05:15 AM
a51fff a51fff is offline
Mein Auto: 2011 X5 50i
the 'grinding' feeling you get on full lock mention in the posts, i get that, have had it from new. have asked dealer to check and they say there is nothing wrong with it! as per usual!!
