Old 03-16-2013, 10:31 PM
Dynamicfigure Dynamicfigure is offline
Mein Auto: 2005 - 645 Coupe
Lurching at 35 mph
My car (a 2005 645 - 88K miles) has started lurching - just a quick hesitation, like it is not getting full power and then a tiny kick when it is over (all in about 1/2 a second) at around 35 mph. The problem was there before but went away for awhile (I quit using the DS mode as it seemed to make it appear - now it seems to go away when I put it in DS mode?). It was not as acute or noticeable as it is now though. Any thoughts, or experiences on the issue?
Old 03-17-2013, 12:24 PM
HerbP HerbP is offline
Are you getting any codes? Sounds like a coil pack is starting to fail, or short out. If this is the case, the jerk happens in a higher gear, at partial throttle. Full throttle will usually clear the hesitation, then run fine. Other problems could be a weak battery, or fuel related problem.
Good Luck!
Old 03-18-2013, 07:56 AM
645/333's Avatar
645/333 645/333 is offline
Michael
Mein Auto: BMW 640i SE Convertible
I would consider also doing a BG44k fuel system clean, at your mileage it is well worth it if you have not done anything before, plus you should also have had the fuel filter replaced by now ?????
Always said I would go back to a 6 series
