Old 03-17-2013, 10:24 AM
gxsrchamp gxsrchamp is offline
Mein Auto: 98 740il
ews-dme sync with pasoft
Can anyone here tell me the step by step procedure to resync the ews3 to dme. I have had no luck finding info on this and do not want to attempt it in fear of screwing it up further. The info I get from pasoft software is so far just a bunch of mumbo jumbo.
Old 03-21-2013, 01:04 PM
kimokk kimokk is offline
**Bimmer DIYer**
Mein Auto: 00 740iL, 97 M3, 06 X3
Take a look at this thread. Maybe it will help your situation.
BMW '00 740il w/230,xxx miles, DIY timing chain guides complete! M60 Manifold, BDC Throttle Body, Performance gearing 3.46 LSD, Magnaflow Mufflers
BMW '97 ///M3/2/5 w/105,xxx miles
BMW '06 X3 w/130,XXX
Old 03-22-2013, 06:54 PM
Mein Auto: 98 740il
OK Well I recieved the scanner and adapter plug in the mail and pulled the error codes and now I am more frustrated. After hooking up the battery the first scan does not pick up hardley any modules. if i turn the ignition to the start position and re scan it picks up all of them but then when I clear the error codes and it rescans it goes back to not finding hardley any modules including the dme. Every time i scan i get different results without me changing or touching anything almost like a loose ground but its always the same pattern first scan-nothing,second scan reads great, 3rd scan-nothing again without wiggling wires or touching anything which makes me think that its not just a random ground problem because it keeps a pattern. So any helpful suggestions ....anybody?
HTML code is Off
