Old 03-17-2013, 10:15 AM
bear-avhistory's Avatar
bear-avhistory bear-avhistory is online now
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
Updated FMIC info
There are some variables in ambient temp but the results are pretty good for comparison.
Originally Posted by TTurboBullett View Post
HELIX-Intercooler Efficiency 86% through 3 gears
Turbo Outlet Temp Calculator
inlet temperature-85
input pressure-14.5
output pressure-14
compressor efficiency-70%
Outlet Temp- 249
Intercooler Outlet Temperature and Pressure Calculator
IC input Temperature-249
IC Pressure loss-.5
Ambient Temp-85
Plenum Temp-108
IC Efficiency-86%
AMS-Intercooler Efficiency 79% through 3 gears
inlet temperature-58
input pressure-14.5
output pressure-14
Outlet Temp- 214
IC input Temperature-214
IC Pressure loss-.5
Ambient Temp-58
Plenum Temp-112
IC Efficiency-79%
ETS-Intercooler Efficiency 78% through 3 gears
input pressure-14.5
output pressure-14.5
Outlet Temp- 213
IC input Temperature-213
IC Pressure loss-.5
Ambient Temp-58
Plenum Temp-93
IC Efficiency-78%
SPEARCO/Code 3-Intercooler Efficiency 54% through 3 gears
inlet temperature-65
input pressure-14.5
output pressure-14
Outlet Temp- 223
IC input Temperature-223
IC Pressure loss-.5
Ambient Temp-65
Plenum Temp-139
IC Efficiency-54%
Kevin
CURRENT:
2018 BMW 440M-Sport MPPSK/MPE 8ZF
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
477 WHP of BURBBLES
HOME FROM PAINT
Old 03-17-2013, 01:40 PM
SuperTerp SuperTerp is offline
Mein Auto: R8, M4, M5. M3, 550, 335i
Hmm. So I guess the Dinan one I'm getting Tuesday is so amazing it can't fit on the list because its so far ahead.
Old 03-17-2013, 02:35 PM
Maybe because the guys testing are interesting in performance over marketing & did not think "Dinan's" still unnamed secret modifications to the Spearco made any difference to the end result More then likely they simply did not have one available.
Kevin
CURRENT:
477 WHP of BURBBLES
HOME FROM PAINT
Old 03-17-2013, 03:36 PM
Top secret always means awesome. Like stealth technology, or hover tanks
Old 03-18-2013, 09:54 AM
daytrader daytrader is offline
Mein Auto: 2010 E92 335i
From the Dinan web site;
"The Dinan intercooler provides a 93% increase in total volume, substantially reducing the pressure drop by 0.7 psi. The intercooler also features larger connector tubing and custom shrouding for maximum efficiency.
"Cool down" time is also reduced, enabling the cars to produce full power under varying driving conditions such as stop and go traffic(or track*). The system has been engineered as a direct replacement for the stock unit, requiring only minor modifications for a clean, factory-like installation."
*(as fellow brother BQ will attest to as he has had longer staying power out on the track than most his fellow brethren, as he uses a Dinan IC).
So, what more could one ask for? More numbers on the theoretical, or plain old track results?
Old 03-18-2013, 10:50 AM
An m6 vert as a loaner while they install it
Old 03-18-2013, 10:54 AM
First, the numbers above are not theoretical but actual test runs with all kinds of supporting logs behind them. Second, no one has said the Spearco/Dinan is a crappy unit, just that its middle of the pack & not worth twice what some of the others cost. Of the group I can see premium pricing only for the Helix. BTW the test showed the Spearco pressure drop to be .5 while Dinan advertises .7 - Better to go with the Spearco number
Kevin
CURRENT:
477 WHP of BURBBLES
HOME FROM PAINT
Old 03-18-2013, 10:58 AM
If that ever happens let me know cause I'm coming out to service my car in your neck of the woods.
Old 03-18-2013, 11:03 AM
Again, I'll go with proven track results. You can carry around all the logs you want.
Old 03-18-2013, 11:04 AM
Its only worth twice as much if you can install it yourself
Old 03-18-2013, 11:40 AM
Labor does seem to be quoted a bit on the generous side for dealer installed so if you can DIY even better of a deal!
Old 03-18-2013, 12:12 PM
If I could DIY I'd honestly don't think I'd get a single dinan part. If I keep the car through graduation, I'm debating on keeping it as a second car and really see if I can learn on it. As it stands now I have no desire to start pulling things apart especially over the weekend when I'll need it for busy weekdays. Plus I get pissed and I'd probably throw a wrench at the car if it pissed me off. Me and princess have a wonderful relationship right now and I'd hate to have the cops called on me for domestic violence
I really can't wait to try the suspension and see how the car runs with an FMIC.
Old 03-18-2013, 12:17 PM
You are making a bad assumption that the others are not successfully used in competition or track days.
I was not in the SEALS so I don't carry logs much.
Kevin
CURRENT:
477 WHP of BURBBLES
HOME FROM PAINT
Old 03-18-2013, 12:30 PM
Its ok to be jealous I'll have the most experienced techs in the automotive industry working on my FMIC. It will be the greatest automotive accomplishment since Karl Benz.
Old 03-18-2013, 12:49 PM
You really know how to hurt a guy
Kevin
CURRENT:
477 WHP of BURBBLES
HOME FROM PAINT
Old 03-18-2013, 01:04 PM
Just break'n balls. Semper Fi!
It's ok I'm hugging my macbook right now hug your monitor and it'll be just like we're together in real time.
Old 03-18-2013, 02:31 PM
Maybe everybody can just do one big group hug. Garry Owen!!
Kevin
CURRENT:
477 WHP of BURBBLES
HOME FROM PAINT
Old 03-18-2013, 03:57 PM
say a prayer for me tonight that I don't get stuck with a 328
Old 04-09-2013, 06:19 PM
I brought it over from the other thread
So you went with the ETS like mine The devil made me say that. Think you will find your new FMIC a big improvement over the stock unit.
I just got home from murdering a GTO 6.0L (not sure if it was FBO but it had an awesome exhaust) it was amazing he was at least 5 cars behind me on this FMIC map my temps were 248-249 the whole way home though and it was 77 degrees. The thing I noticed was when I slammed on it to intially catch him where I would have had a harder time then reaccelerating, it was basically like a first time WOT at like 80 now I don't want to think with DCI, Exhaust and DP's what it would be like
It seems like any temp savings I may have gained from the FMIC (I'm aware it doesn't cool oil ) I erased with the stock 1 fmic aggressive map.
Old 04-09-2013, 07:02 PM
vstM3's Avatar
vstM3 vstM3 is offline
Mein Auto: F80 M3
I read its quite a difference going from stage 1+fmic to stage 2+fmic but you will need the DP and intake. Intake is ok but with DP you will run into problems going to the dealership with the check engine light on...again this is what I've read
Current: 2015 BMW F80 M3
Retired: 2012 BMW 335is
Other: 2014 Mini Cooper
Old 04-09-2013, 07:06 PM
I'll do an oil cooler before I do DP's. From what I've read the jump I'm impressed with right now won't be as noticeable going to stage 2, but it'll still be good.
Old 04-09-2013, 07:10 PM
vstM3's Avatar
Mein Auto: F80 M3
I too think stage1+fmic is plenty for having fun on the streets and its not worth the DP unless you are tracking ur car often.
Old 04-09-2013, 07:40 PM
+1
Kevin
CURRENT:
477 WHP of BURBBLES
HOME FROM PAINT
Old 04-09-2013, 07:54 PM
BuraQ's Avatar
BuraQ BuraQ is offline
Moding is Addictive
Mein Auto: DCT 335is BQ Tuned
Awesome compilation in the OP of upgraded intercoolers available for the N54. However, there is a need to clear up some confusion between the Dinan vs the Spearco
^ The N54 Spearco Intercooler here represented in the OP is a different design/specs/size from the Dinan version
Even though the difference between them can be seen, this picture from Dinan's website is a poor representation as the "end tank connections" are not the connections you will see on the actual product for the N54. Below is a clear example of the Dinan Spearco Intercooler with the exact same end connection as the OEM for easy installation
The Dinan version of the Spearco is larger than the original Spearco Code 3. Dinan's claim is a 93% increase in volume over the stock intercooler
What Dinan did is used the Spearco Core to their size specifications that comes in various sizes http://www.turboneticsinc.com/node/84
http://www.turboneticsinc.com/node/86
As everyone can see and it has been made very clear, the Spearco Code 3 and the Dinan Spearco are:
Difference sizes
Difference design
The only relation is they use the same "CORE" technology, that's its
Another thing to look at in their data specs is that:
The rule of thumb for "coefficient heat exchange" for an intercooler is that it should have "less than" 1.00 PSI reduction
All the FMIC mentioned all meet this rule. PSI reduction range of .20 - .90 the less number does not mean better nor does the higher number
The lower the number means higher flow with less "coefficient" and the higher the psi reduction means lower flow with better "coefficient" as the slow down allows the air to cool more becoming more dense before reaching the intake manifold
I don't want to get into what intercooler is better, I will leave that to the individual. I just wanted to clear up the mistake of the Spearco Code 3 intercooler representing the Dinan version.
