The X5 SAV Forum
Old 03-17-2013, 12:28 PM
craigatkinson craigatkinson is offline
Mein Auto: 2006 BMW X5 4.8is
Blue Smoke on Idle. 2006 4.8is.
I have a 2006 BMW X5 4.8is. I have been having the blue smoke on extended idle issue. I am pretty sure it is the valve stem seals, but wanted to make sure that I have correctly diagnosed the issue before taking the plunge.
I usually see the smoke when I am in stop and go traffic, or going through a drive thru. When I am finally able to give the vehicle a lot of throttle, it spits out a big plume of smoke. I do not notice smoking while driving down the road. I do not have smoke when I first start the vehicle in the morning, or any time it's been just sitting turned off.
I tried to get the smoke to start yesterday in my garage, but it wouldn't smoke unless I got in the car and moved it around a little big in a stop and go fashion. But once I got it smoking it smoked real well.
The lack of smoke when the car starts makes me wonder if it really is the valve stem seals. I have always been under the impression that bad valve stem seals would cause a plume of smoke upon start up, but then once the car warmed up would stop smoking.
I already changed the PCV valves and it didn't change anything, and there was nothing wrong with the valves I replaced. Any help would be appreciated. I read in another forum of someone having the same problem and replaced a bunch of seals and gaskets under the valve covers, didn't replace the valve stem seals, and it fixed his problem.
I'd like to avoid pulling the cams if I can.
Old 03-18-2013, 09:35 AM
dryflyguy dryflyguy is offline
Mein Auto: 2006 X5 4.8iS
I would say its the valve stem seals as well.
Old 08-22-2015, 09:28 AM
tony745li tony745li is offline
Account Under Review
Mein Auto: 2003 bmw 745li
https://www.facebook.com/groups/700477680083131/
*I got the aga secondary air cleaner kit for rent* and the aga valve stems kit for rent as well
Call or text* 414 5172179 tony
Or u can add me on Facebook* at
4.8is, blue smoke, idle, valve stem seals
