2001 740IL-Power steering pump cracked......how long? - Bimmerfest - BMW Forums
Old 03-17-2013, 01:07 PM
onceuponamarine onceuponamarine is offline
Mein Auto: BMW 740IL
Hello everyone,
I was driving my "baby" down the street and all of a sudden, the steering wheel locks up!!! The battery light came on (just got a new battery 4 months earlier).I happened to see an Advance Auto and muscled my car into the parking lot. Difficlt to drive with no power steering. Anyway, I pop the hood, and my dam serpentine belt was dangling from the pulley!! The belt that goes around the power steering pump and pulley....
Advance had one for $15, but Firestone would not put it on because of their "warranty" policy. I ended up driving two miles down the road to the firestone and had them replace the belt. After they put her up in the air, I saw the power steering pump had a crack, and the bolt came out, which mde the pulley "stick out", which caused the belt to become tangled from the pulley.
The power steering pump, after getting a quote from the dealership, costs $850.....and another $668 in labor! Are you freggin kiddin me? I told firestone to put the bolt back in the housing unit and tighten her up good. My question to you guys is, "How long do I have before I need to replace the pump for good". I know I need to replace because of the crack, but it is not leaking oil or anything, it's just cracked.
Any suggestions other than, "replace the pump", since I know this needs to be done. Has anyone else driven with a cracked power steering pump? The car drives smooth now, the steering wheel turns smooth too
Old 03-17-2013, 03:32 PM
kimokk kimokk is offline
**Bimmer DIYer**
Mein Auto: 00 740iL, 97 M3, 06 X3
Look for a remanufactured one or pull one from a local parts yard if you have one in your area. You might want to check your belt tensioners too. Mine seized and caused the belt to snap. I wouldn't drive too much with that cracked pump though.
BMW '00 740il w/230,xxx miles, DIY timing chain guides complete! M60 Manifold, BDC Throttle Body, Performance gearing 3.46 LSD, Magnaflow Mufflers
BMW '97 ///M3/2/5 w/105,xxx miles
BMW '06 X3 w/130,XXX
Old 03-12-2014, 02:14 PM
Djscorpio67 Djscorpio67 is offline
BMW ENTHUSIAST
Send a message via Yahoo to Djscorpio67
Mein Auto: e38 '01' 740IL Sport
Exclamation
The exact same thing happened to my 2001 740iL today. My indie mechanic quoted me $650 for a new BMW PUMP with 2 yr . warranty. Bavauto carries a reman genuine BMW pump with 2yr warranty for $384.95 including a $60.00 core charge. So my indie is calling to see if they can get the price knocked down some on the new pump. (Yes my indie ROCKS!)
My other car is a PLYMOUTH Neon
Old 03-14-2014, 04:32 PM
tomloans tomloans is offline
Mein Auto: 2001 740i Sport
Originally Posted by onceuponamarine View Post
Hello everyone,
You can get a remanurfactured pump for less than half new and they work well. Just replace it. You don't want to harm your steering box because of a $200.00 part.
Old 03-14-2014, 05:04 PM
BMW ENTHUSIAST
Exclamation DIYers check this!
DIY tip. Check your pump bolts on these cars to save you a hefty bill. Got the new pump for $550, plus a new belt, fluid, and labor for $850 out the door. Bavauto had a 3-5 business day wait because they were out of stock. And I couldn't be down that long. Wanted to make sure I got the pump from a reputable company.
Old 03-14-2014, 08:53 PM
aom aom is offline
Moderator
Mein Auto: 750i 740i 330ci
Same here, the bolt hole actually cracked and the pump was dangling from the bottom of the car, luckily, I caught it and managed to tow it before any serious damage. It's an easy DIY, cost me about 300 in parts. I could now do the whole thing in about 30-45 minutes.
F01 750i Dark Graphite Metallic M-Sport Packages: Driver Assistance | ARS | Luxury Seating | Camera | Convenience | Premium Sound | 20" 303M Wheels | Ceramic Controls
BMS Stage 1 Tune | Pedal Box | M-Sport Paddle Shift Steering Wheel | 5000k HID | Tint | Mtec Angel Eyes LED | Rear Tinted Taillights | Coded
E38 740i Black Sport Packages: PDC | Convenience | Sunshade
Paddle Shift Retrofit | Brushed Aluminum Gauge Ring | Modified M-Sport Steering Wheel | Tint | MKIV NAV | 4500K HID | 3M DiNOC Carbon Fiber Trim | Heated Seats | Refinished M-Parallel Wheels | Celis Tails
My PedalBox Stealth Install: http://www.bimmerfest.com/forums/sho...d.php?t=725889
Old 03-15-2014, 04:13 AM
BMW ENTHUSIAST
Next time Up call you. Book time is 1.8hrs.
Old 03-15-2014, 09:52 AM
aom aom is offline
Moderator
My first mistake was not having the fan clutch wrench and holder tool... pretty much impossible without it. But once I got it, the rest was pretty trivial. One of the easier jobs to do (alternator would have been even easier if it weren't for the stupid draining of the coolant.
Old 03-15-2014, 11:59 AM
BMW ENTHUSIAST
I have the Zionsville heavy duty cooling system (electric fan) so you'd have mine done in no time flat. ;-)
HTML code is Off
