Old 03-28-2013, 07:54 AM
booyaazaa's Avatar
booyaazaa booyaazaa is offline
Mein Auto: '09 AW 535i, Fiat 500e
Originally Posted by HPIA4v2 View Post
I thought that was "sb55" not "gila06" that got walnut blasting at no charge, Gila06 only got plugs replaced @45k. My bad if I misquoted, hard to read line per line on all posts
That's cool. There's quite a bite of people chiming in with this problem. If Gila06 has not done the blasting then that would be a good next step.
2009 AW 535i
-Sport, Premium Package, and Comfort Access
-FBO, custom Cobb E45 map, Fuel_it Stg2 LPFP, Performance Gearing LSD.
Follow on IG: Booyaazaa
Old 03-28-2013, 07:57 AM
booyaazaa's Avatar
Originally Posted by billyp View Post
My 08 535i is having the same idle issues and it started after getting the spark plugs replaced around 64K miles. I will be bringing it in within the next few weeks and will let you know what they find out.
Hopefully that wasn't your first plug change at 64k.
2009 AW 535i
Old 03-28-2013, 08:01 AM
billyp billyp is offline
Mein Auto: 2008 BMW 535i
It was and my car ran a lot better before the change...
Old 03-28-2013, 09:28 PM
Gila06 Gila06 is offline
Mein Auto: 09 535
Thanks for all the suggestions. I dropped my car off to the dealer today. The shop manager wants to drive it for a few days. I took several of your advise (driving it like i stole something and "loading") And the car actually drove alot better and it seemed to idle alittle bit smoother.
I didnt get any codes. Ill keep you posted.
Thanks again....
Old 04-09-2013, 08:12 PM
Mein Auto: 09 535
Update:
the dealer kept the car for a week. Drove it , ran all kind of test and pressure test, and didnt find anything wrong. I have a cpo so there is plenty of warranty left.
The funny part, before i dropped the car off, i applied the advise mentioned in this post. I drove the car hard, kept the rpms at 3-3500 for several miles to heat up the engine and drove it like i stole something. The car actually runs better and the gas milage is improving. I will make this a monthly practice.
Thanks again.
Old 04-10-2013, 04:42 PM
Update: Brought my 535i in last week due to intermittent engine sputtering and ended up getting a bad ignition coil replaced under CPO. They also replaced a leaking oil housing gasket and leaking mechatronic sleeve seal, also under CPO warranty. The car runs a LOT better but I still have higher than normal engine vibration at idle, particularly, the air filter housing vibrates a lot. Love the car but not all the problems with 67K miles.
Old 04-10-2013, 05:36 PM
Mein Auto: 09 535
Yup, I feel your frustration. I have two good friends with our cars and they dont have our problems. It has to be the plugs.
