Old 03-17-2013, 03:18 PM
RIHI RIHI is online now
Mein Auto: BMW
Help with removal of shifter.
On a 2008 535XiT Auto, how do I remove the shifter, to replace it?
Old 03-17-2013, 03:38 PM
pcy pcy is offline
Mein Auto: '06 530i, '07 C280, ML320
Pull up and remove the shifter knob.
Then, remove the trim around the shifter.
Disconnect and remove the shifter.
Old 03-17-2013, 06:29 PM
Mein Auto: BMW
Thank you, I'll try that.
Old 03-17-2013, 07:03 PM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
You're supposed to be able to pull hard enough on the knob and it will come off. I've never been able to get mine off, though
Old 03-17-2013, 08:39 PM
gmnmsclM540i's Avatar
gmnmsclM540i gmnmsclM540i is offline
545i pilot
Mein Auto: e60 545i e34 540 e32 740
Id put the shifter in second gear before pulling, as suggested on another thread, to keep from breaking my windshield or sunroof.
Sent from my DROID RAZR using Bimmer App
Old 03-17-2013, 08:42 PM
Mein Auto: BMW
How do you do that with an Auto?
Old 03-17-2013, 09:19 PM
545i pilot
Im a dumb a$$.
Old 03-27-2013, 11:22 PM
Mein Auto: BMW
It actually pulls up to remove but the shifter cannot be removed since there are two ribbon wires attached to the shifter. I could put up a DIY, with pictures but I don't have any way to host the pictures. So here it goes without pictures:
1. First remove the shifter surround;
2. Then, there is a ring below the black and aluminum piece that needs to be moved down;
3. Use a flat blade to remove the surround of the side button (used to shift to Reverse). There are two places (top and bottom of surround) that is needs to be pried slowly.
4. Once that is removed, the front plate (aluminum with LED lights needs to be pried from the bottom going up, while pushing the P button to be able to release the front plate.
5. Once that is removed, the ribbon wires can be removed from the shifter;
6. After which the shifter itself can be pulled off straight up.
Assembly is the reverse.
Let me known if there are questions.
