E90/E91/E92/E93 (2006 - 2013)
Old 03-17-2013, 05:37 PM
dodadnules dodadnules is offline
Mein Auto: 328i
Question High Brake Light Glued On?
Hello All,
Just bought my first BMW yesterday. It's a 2009 CPO with ~36K miles. It came in off lease and is in near perfect condition. So far, I love it but, I had a weird thing happen today.
I was trying to clean under the rubber boot that sort of seals the LED bar for the high brake light against the rear window. The boot seemed to flex down a little allowing me to wipe dust and some crud out of there. In the process, something "popped and now, the boot is loose.
I took a close look and it appears the LED bar/boot assembly was GLUED to the rear window. I think I popped one end of it loose.
My Mercedes had a very obvious and deliberate clip to remove the lens, clean, and replace the bulbs. Maybe since LEDs virtually never burn out, they thought permanently gluing it in place was acceptable. The problem is, there is no way to get in there can clean the glass, etc., with this design.
Anybody have this happen and how did you fix it? Just glue it back on?
Any and all help is appreciated.
Old 03-17-2013, 06:36 PM
tturedraider's Avatar
Freedom isn't free!!
It's not glued in place. It's held in place by two clips
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." -- Geo. Orwell
Keep Right, Except to Pass
Then & Than usage - "It was hotter than ever (comparison). Then (time) it got cool."
2006 330i Sonora w/ ActiveAutoWerke flash tune - I like it!
2004 330i ZHP Imola/NB - missed
2000 328i TiAg - gone but not forgotten
BMW CCA member #388003 - www.bmwcca.org Use me as a referral, you could win a one day ///M Driving School!
Old 03-19-2013, 11:49 AM
Mein Auto: 328i
Actually, it's glued. Found the pad of glue on the glass.
I glued it back on so, no worries. Just seems like a chinsy design.
Old 03-19-2013, 12:34 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is online now
Flying monkey herder
Mein Auto: Daihatsu Terrios
the light clips to those pads. you release the clips before pulling down the light.
much like how the rearview mirror is glued to the windshield.
if you release the clips properly, the mounting post shouldnt be ripped off the glass
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Present: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Old 03-19-2013, 12:54 PM
Mein Auto: 2007-335 HTC
yep and the saga starts with another new BMW owner
have fun, just remember if you think its easy to do, best think again!
Old 03-25-2013, 01:10 PM
Mein Auto: 328i
Thanks and, I believe you but, I just cannot see any way to release any clips. On my car, there are 2 aluminum pieces, one at each end, that fit into slots on the plastic LED housing. These aluminum pieces are glued to the rear window with a semi-flexible gray/black adhesive somewhat similar to silicone. I wound up pulling off the other side so I could clean everything properly and then glued the assembly back to the window.
There are clips, to be sure, on the trim panel cover that is the same color as the headliner. That comes off with no problem. Then, the assembly with the LEDs, wiring, rubber boot, etc., is glued to the glass. There are no removable clips, at least that I can see/find.
Maybe I shouldn't divulge this but, I'm an engineer and VP of R&D for manufacturer of complex electronic/mechanical devices. I have some experience with clever clips and latches but, to be sure, can't see anything here.
Would love to know the secret.
Dave
Old 03-25-2013, 01:12 PM
Mein Auto: 328i
Hey, we all have to start somewhere......
