Old 03-18-2013, 01:23 PM
venus venus is offline
Mein Auto: 2005 530i
2005 530i stalls
When driving up the hill it keeps loosing the speed and the rpm doesnt increase even given more gas. Have to shift to lower gears to keep the rpm about 2800 for it to keep moving. If I dont shift the gears, transmission disengages and the car stalls.
When accelerating from zero, the engine gets very rough. It seems to drive better when the engine is cold. Mileage dropped by about 5 mpg.
When it is in Neutral, it revs up OK.
Dealer gave an estimation of about $5K repairs for replacing 4 oxygen sensors, catalytic converter and MAF sensor.
Got the 2 intake Oxygen sensors replaced by an independent mechanic. It did not make any difference.
Error codes after the replacement of oxygen sensors:
28A2:
28A2 Air path
Error will cause a warning light
Error is not currently present
Test conditions have been completed
Short circuit or signal interruption
273D:
273D Cat-converter bank 2
Signal or value below threshold
2738:
2738 Cat-converter bank 1
CDA8:
CDA8 Telegram monitoring (status instrument combination, 1B4)
Error will not cause a warning light
Timeout
Replaced the MAF sensor myself. No difference. Mileage dropped further.
Error codes after the MAF replacement.
28A2:
28A2 Air path
5F77:
Appreciate any suggestions.
Old 03-18-2013, 02:29 PM
pjinca pjinca is offline
USAF Pararescue Veteran
Mein Auto: 2008 550i
Check the oil separator - the hose connections to it frequently crack or become brittle over time.
Check the PCV valve.
Check for bad coils/spark plugs
Even if you replace everything I listed here it should be less than $1k at an indy shop, the dealer is trying to rape you. I replaced the oil separator (cracked) on my old 530 for $160 parts and labor.
When my oil separator cracked I had 4 pages of error codes, including misfires in 5 cyls, increased emissions, secondary air pump, O2 sensors all showed as bad, and the Cats were showing as bad. Once I replaced the oil separator and reset the error messages, they never returned, car ran perfectly smooth.
2014 535i - MSport, HUD, NAV, Prem, Surround View, Driver Assist
2008 550i (R.I.P.)
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
