E90/E91/E92/E93 (2006 - 2013)
So.... Small nail in runflats turns into inside damage to tire...please read...
So this morning i fired up the car and the tpms monitor told me my left rear tire was low. I checked the pressure and it was at 34lbs. I added air back up to 44lbs. I noticed the small screw in the center of the tread. I removed the wheel and brought it in loose to americas tires. I have used them for about 10 years. they had a hard time removing the tire from the wheel. they then told me that there was damage to the inside of the inner tire. it looked like a gouge mark along the entire inner shoulder area. i looked at the damage and thought maybe it was from their tools. the guy said its from the tire being low and driven on. I never drove on the tire after the sensor went off. could the damage occur at 40lbs of pressure. the tires have about 1.3 years of use on them. i moving to a full set of pilots tomorrow...argh
It is highly unlikely that damage was caused with pressure in the tire as you describe (IMHO). There are very few other explanations.
Black Sapphire Met., Black Dakota Lthr., PP, Moonroof, convenient electronic "dip stick," Steptronic. ------------------------------------------------------------------------ E90 328i E92 335i 6MT E46 M3 6MT E39 528i 5MT MBz W140 S320 MBz W124 300E (slammed) (unmentionables in between) '71 AMC Javelin (4-Spd Stick on the floor) '67 Pontiac Firebird 'cabrio' (1st car - "the leaker") ------------------------------------------------------------------------ Member: BMW CCA |
screw was in middle of tire, only 1/2 long. i did not drive when tpms went off at 34lbs. i wonder if the lower pressure (until tpms went off) with the higher negative camber that bmw uses on the rear would cause this. well see what the other rear looks like tomorrow....
Didn't they indicate to you that the tire was leaking air at the 'screw'...had gone all the way through the tire's tread? A simple test of soapy water (bubbles) before the tire was dismounted (after applying some air). This is not rocket science. BMW's tire supplier's give detailed and explicit (photo) advice for RF tire interior damage due to "runflat," or "0" pressure 'running' that is available to all retail tire dealers (of course, BMW dealers will not repair tires). This advice is meant as a specific guideline to LIMIT the extent of interior damage that MAY NOT be repairable. I might be able to find the links.
did you drive a reasonable distance with the nail ?
most cases can be fixed... however some shops won;t fix as it's difficult to take the tire off you have to beg them RFT are Piece of shxt
06 130i 07 320i 08 E92 325i Bicycles: Giant TCR Advanced Zero, Argon 18 Krypton NEXT CAR : A PORSCHE
nail was the leak. im not sure how long i drove with nail, it made no noise. as soon as tpms tripped i took wheel in. it was a slow leak. so tire could have been at 36psi for a few days. Id like to see those damage protocols.
Tire brand? I've had Goodyear patch a nail hole in one of their run-flats ...... others are paranoid about touching one of these abominations ....
Laser ___________________________ 2011 535i Black Sapphire Metallic, Sport, Euro Del (ret) 2009 328i Black Sapphire Metallic 2007 Honda S2000 Berlina Black |
bridgestones, i picked up the car early jan of 12 under cpo. the tires were new to very new at that time. i put 20k on them so i guess its to be expected....
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
