Backer Plate Advice / Word to the Wise - Bimmerfest - BMW Forums
Old 06-14-2013, 12:26 PM
ChefJRD ChefJRD is offline
Mein Auto: '03 530i manual, 120k
I set out to do the rear brakes and rotors quickly one evening last month. I should have known better – when I think anything will be quick, it’s usually anything but…
Word to the wise (aka, advice from a dummy): release your parking brake when removing rear rotors!!
I read a DIY post that talked about hammering off a rusted rotor, so had “hammer it” in my head going in. When the rotor didn’t come right off, I kept hammerin’ away. I got it off, but it turns out I was hammering the rotor off of the engaged parking brake, messing up the backer plate along the way. I got the new rotors and pads on just fine (AFTER releasing brake), but at least one side is squeaking rather frequently due to the bent backer plate rubbing the parking brake shoes against the rotating rotor (as I learned along the way, the parking brake drum style shoes are mounted to the backer plate).
So now my question… Does anyone know how to replace the rear backer plates on an E39? I haven’t been able to find schematics or forum posts, other than one that referred to having to remove the hub and bearings, but that was in a track forum and I think it was a 3-series. RealOEM makes it look like all you have to do is remove the rotors (pic below). Does anyone have experience with this?
Our first child was born a few weeks ago, so my threshold for bringing it to the shop is beginning to lower...
Old 06-14-2013, 12:50 PM
cn90 cn90 is offline
Just hammer it back out.
Too much of a headache to replace the backing plate.
Old 06-14-2013, 01:18 PM
How do you recommend? By removing the rotor to get down to the backer plate and parking brake equipment, then hammer/bend from there?
I just found your awesome parking brake write up. That's making me wonder if I should replace the pads like you did since they've been rubbing so much lately, and likely not evenly.
Not sure if there's any difference, but mine is an '03 530i (just updated my signature from the previous '97 528i - may she rest in peace...).
Old 06-14-2013, 01:20 PM
Yes I wrote that DIY.
Do not remove bearing (a PITA job).
Once the parking brake shoes are removed, you already get down to the plate.
Then hammer it gently until it is smooth again.
Old 06-14-2013, 06:00 PM
JimLev JimLev is offline
You will need to remove the axle and the wheel hub assy to get the backing plate off. Big job, just hammer it back into shape like CNN said.
Old 06-17-2013, 12:50 PM
Thanks, everyone. I'll give the hammering/reshaping technique a shot. Though I'm not sure when - with the 1 month old, this proud Pappa doesn't have much free time. Hopefully one of these weekends coming up.
