Navigation problem - Bimmerfest - BMW Forums
Old 03-19-2013, 05:47 AM
OB740IL OB740IL is offline
Mein Auto: 2001 bmw 740il
Navigation problem
Hey everyone i have this problem with my 4.3 inch screen it doesn't work the screen it self just dark blue and it has some lines going across and the radio shuts off by itself every other minute i have to turn it off and back on again for it to work. So the question is can it be fixed or should i start looking for a new radio. Thanks
Old 03-20-2013, 05:59 AM
Giddyup7585 Giddyup7585 is offline
Mein Auto: 2000 BMW 740i
Ya, I am have having the same issue. My radio goes off after 2-5 minutes, but the Nav is on, but no picture just fuzzy lines that move around. I read on here that it could be the Navigation unit in the trunk that is going bad, not the radio itself. I could be wrong.
Old 03-20-2013, 06:28 AM
chrisn7 chrisn7 is offline
Mein Auto: 750iL
If there is no TV module, the nav controls the display, therfore nav is faulty.
Old 03-20-2013, 06:30 AM
thank for the reply. Could it be a bad screen ? or should i just replace the whole unit ?
Old 03-20-2013, 05:26 PM
Mein Auto: 750iL
Well the LCD screen is pretty reliable. Although I replaced mine because of marks on the coating (an easy job), I have never heard of a screen failing. Remember the head unit is just that - radio, tv, nav, dsp modules are all in the boot (trunk). Did the radio issue and the display start at the same time-I suspect these are separate problems. Display issue is the nav, and you might want to check which radio module you have- BM24, BM 54, then search on this to see common PCB solder problems
Old 03-20-2013, 06:24 PM
MoezEnt MoezEnt is offline
Send a message via Yahoo to MoezEnt
Mein Auto: 98 Bmw 740 il
I had the same problem before. Buy a new computer, I found one for 100 bucks at some car lot problem solved. Don't disconnect the battery till the nav goes to sleep. the computers are sensitive to battery shortages.
Old 03-20-2013, 08:16 PM
sealbeach740 sealbeach740 is online now
Mein Auto: 2000 740iS, 2003 540iS
+1 - good info.
Or, if you want to be sure, borrow a Nav unit from a buddy & test it in your car. If your radio now works OK, you do need a replacement Nav. Even further, put your (maybe) bad Nav in your buddy's car & see if his radio shuts off after a minute.
You can also test for a bad Nav by when the radio shuts off, if you turn the radio off & then back on, does it come back on for a minute & then go off again? If yes, you need a replacement Nav.
If you have a 4x3 monitor/screen, you most likely have a MKII Nav unit. The MKII is notorious for going bad if the power is removed (battery unplugged or Nav unplugged) before the Nav is allowed to gracefully power down (red LED going out).
2000 740iS. MKIV, 16x9, DDEs controlled by Euro fog light switch, reversed steptronic +/- pattern, paddle shifters, clear corners, Basslink, iPod video with stereo audio, TV tuner, gauge rings, ///M pedals, backup camera with 'on demand' switch, quad brake lights, Dinan engine & tranny software, windows/sunroof close via remote.
2003 540iS. MKIV, 16x9, PDC, CWP, TV tuner, backup camera with 'on demand' switch, paddle shifters, windows/sunroof close via remote, iPod video & audio.
Old 03-21-2013, 06:34 AM
Mein Auto: 750iL
Originally Posted by sealbeach740 View Post
+1 - good info.
I thought it is the MkIII that where you have to wait for it power down properly? Had MkII but never bothered to power down, and never a problem, now on MkIV
HTML code is Off
