E34 (1989 - 1995)
Old 03-19-2013, 08:16 AM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 99' 540i M-Sport
535i radiator questions
So I'm doing a M30B35 swap in my e30. I noticed that the Auto trans radiator is a 2 row radiator with the trans cooler fittings built in. I noticed the manual trans radiator is a single row with no fittings which makes sense. My question is this: Can I use the Auto trans radiator and just adapt the built in trans cooler to a oil cooler? I heard some of the M30's come with a oil cooler, mine did not. I just wanna make see if anyone has done it? I wouldn't think the oil pressure would be any higher than trans pressure, so I think it would physically work but wanna get everyone's advice.
BTW, my M30 has a manual trans.
1999 540i M-Sport
Silver/Black
Still fresh and Minty
1985 335i
Black on Black coupe 5spd
R.I.P
1979 Trans Am 10th Anniversary
#16 of 5,683 made
KOI Import Parts-- 513-771-7777
Old 03-19-2013, 08:23 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Very interesting question.
I don't know the answer (but it certainly seems plausible), but will be looking forward to see what those in the know have to say.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-19-2013, 08:36 AM
Newman271's Avatar
That Guy
I just want to keep everything as cool as possible. I already have to modify my front frame rails to adapt the 5 series radiator so I figured I might as well modify it for the slightly larger radiator. I plan on running this engine pretty hard, so just trying to be careful.
1999 540i M-Sport
Silver/Black
1985 335i
R.I.P
#16 of 5,683 made
Old 03-19-2013, 08:55 AM
BMR_LVR's Avatar
Humble E34 lover
I love the idea and concept of it. I really can't see why it wouldn't work, but again, there may be some reason that I'm not aware of. I'm not sure where your outlet and inlet oil lines would come from on the engine, but again, interested to see what others have to say.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-19-2013, 09:24 AM
ross1's Avatar
ross1 ross1 is offline
Mein Auto: Pretty much had 'em all
I don't see why not. Engine oil pressure is well below the pressures seen in the trans.
I don't know how much cooling you'll get as the temps aren't that different. You'll be adding capacity which is always a good thing.
Me, I'd go oil/air but this sounds like an interesting experiment.
Take my advice, I'm not using it.
Old 03-19-2013, 09:53 AM
Newman271's Avatar
That Guy
My M30 had the oil filter housing on the side of the block.. it has the replaceable paper filter. It looks like my external housing has a bolt blocking a hole for a oil cooler connection.. Just not sure where to put the line coming from the cooler too. If worst comes to worst I could tap my oil pan for the return line.. I'd rather not but as of now looks like A option. Although it would have me one step closer for my turbo build next year..
1999 540i M-Sport
Silver/Black
1985 335i
R.I.P
#16 of 5,683 made
Old 03-19-2013, 09:32 PM
snowsled7 snowsled7 is offline
The Ornery Old Man
Mein Auto: GTI
I do not think trans fluid in the cooling loop see's more than about 10-15 psi, engine oil pressure runs higher than that. I don't think the trans cooler is up to engine oil cooler duty. Consider that you can buy an aftermarket trans cooler for $30-40 but an engine oil cooler is at least double that.
Any specs on trans cooler line pressures?
Current ride... '13 GTI Wolfsburg
BMW's from my past...
'92 535i/5 '89 325ix/5
'98 750iL '86 325(e)/5
'95 740iL '84 318i/5
Old 03-20-2013, 07:06 AM
Newman271's Avatar
That Guy
So I called Spectra Premium, the company that makes the radiator I'm about to buy. They said their coolers built in radiators have a bursting pressure of over 150psi. I told them what I was planning on doing, and said that they have heard of people doing what I am doing.
So, I guess tonight im going to find out how to tap my oil filter housing for some lines to the radiator.
1999 540i M-Sport
Silver/Black
1985 335i
R.I.P
#16 of 5,683 made
