E36 (1991 - 1999)
Old 03-19-2013, 11:20 AM
lovethebimmer lovethebimmer is offline
Mein Auto: 1997 BMW 328i
My 1997 BMW 328i Is OVERHEATING HELP!!!!
hi everyone
i have a 97 328i e36 and its overheating i took it to get fixed but on the way there it started to overheat then it shut off.
i have no clue whats wrong, when i drive it the coolant in the coolant res goes down then when i wait till it cools i unscrew it and it comes back to full.
i check the oil and on the cap and around the rim is this white stuff.
i dont know whats wrong please help if you need more info let me know
Old 03-19-2013, 11:24 AM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
Not good news: you've blow the head gasket. Maybe warped the head, too. By running it until it shut off, you killed it. It should have been shut off as soon as it started overheating the FIRST time and towed to the repair shop. Sorry, but you're looking at a major repair bill. DO NOT drive it again until it's fixed.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 03-19-2013, 11:26 AM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
Cheaper to replace the engine, chief. Don't worry, you will be back on the road sooner than you think. Expect to pay $800 - $1100 for a M52B32 for your 328IS.
Old 03-19-2013, 11:30 AM
thanks thats what i suspected i have a head gaskets set. can anyone give me some info one the job
Old 03-19-2013, 11:34 AM
D'oh, You Kids!
You'll need more than that, but here you go:
http://www.pelicanparts.com/bmw/tech...ead-Gasket.htm
Notice that it's considered a 9 out of 10 job in difficulty. With the special tools and skills you'll need, I'd consider it a 10 out of 10. It's not a job for the novice.
Quotes to live by:
BMW-CCA #441426
Old 03-19-2013, 11:40 AM
ok thanks for the help
Old 03-19-2013, 11:47 AM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
Swap the engine b/c you will spend more getting the job done b/c the head is most likely warped.
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2001 330i DD
Old 03-19-2013, 12:18 PM
hnaz's Avatar
BMW CCA Member
Just swap the engine dude. Seriously. It's cheaper and faster.
Bavarian Auto Recyclers give some crazy good prices on their engines and they test all engines before they leave their facility and give you the compression ratio readings as well.
Old 03-19-2013, 01:39 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Er, make that a M52B28.
1998 BMW 328is
1966 Pontiac GTO
Old 03-19-2013, 08:03 PM
hnaz's Avatar
BMW CCA Member
AAiiieee!! You're right.
Sorry for the typo.
