E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
Cracked Head, What Now?
The machine shop tells me the head is cracked and used ones probably aren't the best idea. The cost of a new head (that they would charge me) is $1200. By the time I get my e30 back the bill will be around $2500. What do I do? I just can't afford that? Anybody know where I can get a cheaper head?
Your best bet is finding a good head in a wrecking yard, and having the machine shop clean it up. Look for the latest head you can find, from an M20 engine. This includes e30, and e34. Look over the engine, and look for evidence of water in the oil under the valve cover. One way to get an untouched head, is one with the vin sticker still attached. That head will probably NOT have been skimmed before.
I paid $75 for a used head with warranty, and then pain $218 for it to be cleaned and new guides in California last October. Hope this helps you. I did all the labor on R&R on the engine. |
Salvage yards, craigslist, ebay.. the list goes on. I would never spend that much on a stock head.. You could buy a aftermarket ported and polished head for that costs.
1985 335i ![]() Black on Black coupe 5spd Tokico lowering springs, KYB struts and shocks, BavAuto strut bars, SPC adjustable camber plates, Ireland Engineering rear toe and camber kit, Sparco buckets, Rota Torque 16x7 fronts 17x9.5 rear, Hella headlamps with HID conversion, all red taillights, MSD coil,M30B35 swap, Mustang GT Injectors, Port/Polish
also, since your car is a 89'.. make sure the head comes with the double valve springs otherwise it's a "e" head with single valve springs and will float valves at 5500rpm and prolly Blam-O!! the engine.
I just worry that a parts yard head will be just as likely to crack as the head on my engine that just cracked. I found a rebuilt head on eBay for $700, that seems more reasonable. Is that still too much?
yes. the chances of a yard head being cracked is about 1/1000. it could happen but its rare. i would run to the yards and see what they have. you can still find a much better deal
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming |
If buying a head from a salvage yard, you'll either find one that's already been shaved too much, or has been cracked and sent the car to the bone yard in the first place. So, look for signs of milky oil (bad) and try to get a head that's never been off the engine. (Original vin sticker on head) That's your best bet, in finding a great one. I assume you're looking for an 885 head, so peer through the intake for those numbers, before you start disassembly.
How is it so rare? Maybe the head in a parts car isn't already cracked, but isn't there a higher likelihood that it will crack in the next 50k miles than a rebuild/refinished head?
theres always coolant additives that can help lower the chances of overheating the head. besides doing say an electric fan conversion and running a lower temp t stat, using redline wetter water and a aluminum radiator will help keep the coolant temps lower.
Corrosion is more common than cracks and easier to spot on the gasket faces..
Good - Fast - Cheap: Pick any two. Current: E23 735i; E30 318i; E32 735iL; E38 735iL; R50 Cooper; R55 Cooper Clubman. Previous: E21 318i; E32 735iL; E34 535i; E38 730iL; E53 4.4i
and broken bolts
I have had very good luck with used heads for M50 and M52. Most machine shops will clean and pressure test it for you for under $100. At that point you know if it is solid and can have them do any machine work if needed. Good luck.
94 318i, 97 528i, 07 335i |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
