Fuse - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 03-19-2013, 12:48 PM
E34ZombieHunter's Avatar
E34ZombieHunter E34ZombieHunter is offline
Nothin like an E34
Mein Auto: 95 540i B/B
Exclamation Fuse
For some reason my cooling fan fuse, and cigar lighter fuses keep blowing after driving. Why they both do it, i have checked all the basics. Its getting warmer, and i have noticed the car getting warmer than when its cold out, obviously, but the needle goes past the 1/2 mark after short drives, not far past, but i do not drive far enough to heat up quickly.
Old 03-19-2013, 05:56 PM
Nothin like an E34
Please???
Old 03-19-2013, 06:30 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
See if you can spin the auxillary fan by hand (you may need to reach in with an object such as a long screw driver to reach it). It should spin very freely. The one on my previous E34 failed and would blow the fuse as soon as I turned the A/C on (which causes the auxillary fan to come on regardless of outside temperature or engine temp).
If it doesn't spin freely, then that is what is causing the amperage overload and it will need to be replaced.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-20-2013, 06:17 PM
Nothin like an E34
Well i guess you solved my problem, i could not turn the fan with a stick, removed the grill, and i CANNOT turn it at all. I guess i have to get a new one, could this cause my ac to get warm after a while of running?
