E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
The engine keeps jumping!!!
Hey there guys, i keep having this problem when i hit the gas slowly where its about from 1500 to 2500 rpm the car kind of jump and shake the hell out of me, i change the fuel pump today with the fuel filter but still its the same... Any ideas why???
Injectors maybe??? I have m20b20 which recently made it to m20b23 Oh and one more thing, when the engine gets to the right tem and the rpm goes to 800 it kind of starts playing up and down, its not stable most of the times Last edited by Sammye30; 03-19-2013 at 01:24 PM. |
when you made it a b23, howd you go about doing it?
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming |
I changed the crankshaft n the pistons like it says on the forums, a lot of people did that!!!
Anyways this problem was before i fixed the engine Last edited by Sammye30; 03-19-2013 at 08:49 PM. |
did you do anything else, like bore the walls, shave the head, rebuild the head, replacing timing chain/belt, vacuum tubing, intake boot, ect.
it sounds like a power balance issue, so anything from poor injector flow to a vacuum leak to weak spark.
Well today in the morning it kept turning off when i stop at the stop light and after like 20 min its all gone and working perfectly, i think its the spark plugs or there cables, im gonna buy new spark plugs tomorrow and see what happens
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
