Old 03-19-2013, 06:23 PM
curve001 curve001 is offline
Curve
Mein Auto: BMW 745 LI
Head light height adjustment
I have a 2009 F02. Anyone knows how to adjust the HID low beam to point higher ? Thanks
Old 03-19-2013, 07:42 PM
haastx10 haastx10 is offline
RocknDoc
Mein Auto: 2015 M5 DINAN
The vertical adjustment screw for the drivers headlight is under a small plastic cap in the fender to the right of the light (when standing in front), the adjustment for the passengers is again to the right of the light inside the access panel for the lamp housing. The other adjustment screw (to the left) moves the lights left/right. Note that if you are at the extremes in adjustment of up/down, turning the screw further makes the light move left/right.
________________________________________
2015 BMW F10 M5, Space Gray, Dinan Stage 1 Engine, Exhaust, Coil Over Suspension, Sway Bars, Vorsteiner Staggered 9 /10.5 '20's, Custom Coded.
Old 03-24-2013, 07:07 PM
Curve
Done ! Thanks Haastx10 !
Old 03-24-2013, 07:34 PM
RocknDoc
Glad I could help! Your welcome!!
Old 04-01-2013, 01:51 PM
TXSTYLE's Avatar
TXSTYLE TXSTYLE is offline
The Entertainment Guru
Send a message via Yahoo to TXSTYLE
Mein Auto: 750i (F01)
Trying to adjust these as well. I think I see them. But are they turnable without moving the large cover that ribs along the entire inside fender?
I need to adjust the drivers side horizontal pattern. It/beam is too far right to me at night.
What tool to adjust?
FYI... I just installed xenon type halogen in Fogs. Easiest install ever! Looks fantastic!
BigMarcus ~ EVO 4G LTE
