Old 03-19-2013, 08:45 PM
Dking078's Avatar
Dking078 Dking078 is offline
Member Supremo
Mein Auto: 2003 BMW 540i
Restoring headlights (Final mission) Help.
Okay, a year ago i did a review on the sylvannia headlight refinishing system.
For lack of better word... This kit also failed, but theres more.
The failing point was the clearcoat, while the clear was good, there was not nearly enough, given it was wiped on.
The clearcoat looked good for 6 months on the X5 (which saw rain, snow, & all the other bad stuff) and I reapplied the clear, but now it's just peeling off.
The 540i's have fared much better, the 03' is in good condition, but had some fade, while the 97 is a bit better since it's hardly moved.
Okay onto the main topic...
I want to adress the main problem with the kit, the clearcoat. To make something like this work, I need a GOOD UV clear. I've googled some ideas and have come across Krylon Fusion UV clear coat for plastic, which i've read a headlight redo on. So for that redo, it looked quite good after a decent wet sand.
My question to the forum is, do y'all think it's worth it? Any input on a better clear coat?
2003 BMW 540i [Sterling Gray / Gray]
[Msport] [Mods from A-Z] [Two-Tone Interior]
The one stop trim shop See the Dking Difference [Click]
Stuff For Sale: PM for info
1 Set of E39 OEM Maplewood Trim $220 Shipped
1 Set of High Polished black E39 OEM Trim $275 Shipped
4 E39 OEM Headlight Ballasts $58 Shipped each
E38 Illuminated Interior Door handle set $72 Shipped
Old 03-20-2013, 05:25 AM
Fudman's Avatar
Fudman Fudman is offline
I used a clear plastic covering called Lamin-X. It is a fairly thick, flexible clear plastic coating. I got them because my issue is the salt and sand that gets kicked up on the highways here in New England. They chip my paint and pit the headlamps. The Lamin-X has been on for 17 mos and two New England winters. My headlamps look pretty much exactly like they did after I refinished 'em. Lamin-X is pricey ($50) but seems to work well. I have Xenons and there is no noticeable reduction in beam quality or distance.
Old 03-20-2013, 08:20 AM
Dking078's Avatar
Member Supremo
I had it once, but i screwed up applying it
