The X5 SAV Forum
Old 03-19-2013, 10:14 PM
benzbenz benzbenz is offline
Mein Auto: 2005 X5 3.0i
2005 x5 3.0 check engine light on with r5/FCC fault code table19 5e
I checked the error code table 19 ,5e secondary air system,air mass.
What does it mean, I replaced Maf but the error code came back after I reset it.
Old 03-20-2013, 09:43 AM
upallnight upallnight is offline
Mein Auto: BMW, Lotus, Porsche
It's part of the AIR PUMP F VACUUM CONTROL system. Here an illustration of the system.
Old 03-20-2013, 06:23 PM
thanks for your reply.
but what does falt code: table 19, code 5e mean?
it's said : secondary air system: air mass. what does it mean? which part is wrong?
The car runs ok, I don't feel any difference. well, it's my wife's car, I don't drive it daily, maybe there is something wrong but I couldn't feel it.
thanks in advanced.
Old 03-21-2013, 05:54 AM
Zulu95's Avatar
Zulu95 Zulu95 is offline
Mein Auto: 2001 X5 3.0L
Check everything in the SA system. Start with the vacuum hoses which are the most likely to fail and cheapest to replace. The system only works on cold starts for a few minutes and uses a pump that will squeal like a Shopvac when the pump is the problem. (Item #1)
The image above is from RealOEM.com Work your way through the parts. I know a $7 length of vacuum hose from Autozone cured my SA problem. You may also want to do a Search on xoutpost.com as the SA system is covered there in many posts.
GL.
