Old 03-20-2013, 10:54 AM
dipesh267 dipesh267 is offline
Mein Auto: 2008 328i coupe
windows not closing automatically
2008 328i coupe...
so my battery was giving me issues and had to be jumped a few times. Since then I've fully charged the battery and it's all fine. What I have since seen is that my driver side window doesn't close automatically when pulling on the swith past that point where it clicks. I have to keep holding the switch for the window to close all the way. the passenger side works just fine but the driver side stopped doing that after the battery issue. is this somethign that needs to be programmed becuase the battery died or is there a setting that got reset that I missed? any help would be appreciated.
Old 03-20-2013, 11:16 AM
found this on a website called zpost and it worked.
Initialization comprises:
Erasure of initialization
Reinitialization
An initialization must be performed:
In the event of malfunctions, e.g. no one-touch control function, no opening or if available no comfort function is possible
After the power window drive has been replaced
After work is carried out on the power window mechanism
After a power supply interruption, e.g. disconnection of the battery or disconnection of the power supply to the door
After the door window glass has been removed and installed or replaced
After adjustment work on the door window glass
After adjustment work on the convertible top
After replacement of seals
Erasure of initialization:
Open door window glass fully
Operate power window switch in "Open" position four times within 10 seconds
This erases initialization of the power window, anti-trapping protection and toll function are inactive.
Check whether one-touch control (toll) function is inactive, otherwise repeat procedure.
Reinitialization:
Avoid a break between the two steps!
Operate and hold power window switch in "Close" position (second switch stage)
Once the upper end position has been reached, hold power window switch in "Close" position for approx. 2 seconds longer
