p340 fault code - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 02-24-2013, 06:37 AM
stevepage7 stevepage7 is offline
Mein Auto: 2001 BMW x5
p340 fault code
I have P340 fault code on my 2001 x5 man petrol what does it mean and can I replace the faulty item
Old 02-24-2013, 06:58 AM
Do you mean P0340?
If it is a P0340 code this indicates that a problem was detected in the camshaft position sensor circuit. Since it says circuit, that means the problem could lie in any part of the circuit - the sensor itself, the wiring, or the PCM (Power Control Module). Don't just replace the CPS (camshaft position sensor) and think that will definitely fix it.
Old 02-24-2013, 07:19 AM
P340 fault code
Are both easy to replace if needed,
Old 02-24-2013, 07:39 AM
What engine is in your X? V8 or I6?
If you have the I6 engine M54 here a video link.
Old 02-24-2013, 07:52 AM
Cheers for that, looks fairly easy to follow
Old 02-26-2013, 09:27 PM
tankowner tankowner is offline
Mein Auto: 2001 X5 3.0
Timely post. I also have a 2001 X5, mine is the 3.0 (I6). I was driving along today and as I came to a stop at a red light, stalled out. I restarted and then the Check Engine Light came on. When I got home I pulled the code - P0340. Camshaft Position Sensor A.
I've read that P0340 is the code for the Intake sensor (not the exhaust). I have ordered one and hopefully that will do the trick.
Thanks for the video that is helpful.
Old 03-25-2013, 09:59 AM
If you fix the problem I hope you come back and inform the forum that the problem was fixed. Too many threads posted on similar problem and many people don't come back to inform the rest of the people if the info they received fixed their problem.
