E90/E91/E92/E93 (2006 - 2013)
Removing permanent charcoal air filter
Has anyone done this? I found a discussion on the 5 series forums, but theirs seems to be glued in. Is the 3 series also glued, or is it part of the assembly?
6 screws hold the cover and filter to the base. Remove the screws, pop the cover off, pop the microfilter out, put a new one in, screw it back down. Pay attention to the orientation of the filter as it comes out. It only goes back in 1 way, but there's 4 ways you can position it (1 correct, 3 wrong) if you're not paying attention.
2009 335i xDrive coupe, Jet Black, Black Leather, Grey Poplar, Steptronic, ZPP, ZSP, ZCW, iPod/USB, HD radio, Parking Assist. Rear Fogs, Hardwire V1, ProFit G3. ED May 12, 2009, Munich dropoff May 16, Redelivery June 22, 2009 Prior 33 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette (kept until first Bronco) / 1981 Subaru GL wagon AWD / 1983 s10 Blazer 4x4 (big mistake) / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion |
This one on the left: Last edited by ptrcd003; 03-20-2013 at 01:49 PM. |
no we don't have one.
If you like customer service. Don't look beyond a BMW. |
It's not glued in on the E60, but secured by clips albeit extremely tough clips. They're removable, and a few people did even though it says do not remove on it. There's a bit of a deeper sound on WOT and a 1-2 MPG increase at best.
Check your mirrors as often as it takes for you to know where everyone is around you! |
If you indeed have one you can choose to remove it by prying a flat tip screwdriver between it and the side of the air box itself. Pry the corners and work around, it should pop out.
Absolutely nothing wrong running without it. I've had mine removed over a year now, and coupled with an RPI scoop and K&N filter. The sound is noticeably different under load. EDIT: The increase in MPG was due to the fact that I did a bunch of maintenance on my car at the same time, (coils, plugs, belts, hoses, coolant, oil...) so the MPG may or may not change
Check your mirrors as often as it takes for you to know where everyone is around you! Last edited by boramkiv; 03-20-2013 at 03:42 PM. |
Just tried, and it seems like the filter is built into the air box? I do not see a seam, and the plastic around it actually cracked when I tried to try it apart with a screwdriver.
It's not built into the airbox on the E60, and im sure it is not on the E90.
Here's mines removed: http://www.bimmerfest.com/forums/alb...ictureid=26627
Check your mirrors as often as it takes for you to know where everyone is around you! Last edited by boramkiv; 03-20-2013 at 03:31 PM. |
My best recollection of how most people remove it is by cutting it out.
Keep Right, Except to Pass Then & Than usage - "It was hotter than ever (comparison). Then (time) it got cool." 2006 330i Sonora w/ ActiveAutoWerke flash tune - I like it! 2004 330i ZHP Imola/NB - missed 2000 328i TiAg - gone but not forgotten BMW CCA member #388003 - www.bmwcca.org Use me as a referral, you could win a one day ///M Driving School! |
The issue is the part number could not be found on that filter at all so it could be replaced. If you needed to order it, you would have to order the whole intake silencer which is ridiculous.
It's held together by clips on the E60. I can't imagine it being part of the box on the e90. It's not listed here: http://www.realoem.com/bmw/showparts...48&hg=13&fg=20
http://www.e90post.com/forums/showthread.php?t=21590
Check your mirrors as often as it takes for you to know where everyone is around you! Last edited by boramkiv; 03-20-2013 at 03:47 PM. Reason: Guess I need to stick to the E60 forums...facepalm!! |
Just make sure that when removing something like that, you can put it back together if needed. Cutting it out might result in a lot of work if you have to return it to stock. Neatness counts.
1983 Datsun 280ZX Turbo 2009 BMW 328iX Coupe 2007 Nissan Murano |
Finally got it out. Cut the filter, then used a dremel with a sanding bit to clean up the edges. If, for whatever reason, I need to replace it, I can pick up an entire silencer box from a junkyard for around $50. If anyone plans to do this, make sure you soak the filter first to avoid dust.
Really doesn't seem to make sense to cut it out in a 328, the only difference that can be felt is if you use a less restrictive (and less filtering) K&N filter instead of the OEM, even then effects have been minimal. But if you already did it, make sure there are no lose particles anywhere that could get sucked into the engine
i removed mine, it was glued on, just cut it out with a blade. heard it was a emmissions thing when you turn off the car, it doesn't spit carbon out into the air backwars or soemthing. i donno
i also added a k&n filter. on my 330i, it was more free revving, especially at higher rpms when the final stage of the intake opens up. so far, over 10k and no issues. all running perfectly well. |
It also doesn't make any sense to do it on a 335i. Any benefits perceived from doing so are entirely placebo.
From a weightlifting perspective, removing the carbon filter is the equivalent of taking tribulus. |
While we are on the subject of K/N filters, is it really worth adding this over the OEM filter? I read somewhere you should not attempt to clean it, but instead just replace the entire filter with a new one.
i don't think k&n adds any power, just cleans up the power band and throttle response. Last edited by racermp; 03-22-2013 at 08:14 AM. |
They are good filters. The fact that you reuse it makes it cost effective overtime. The sound is nice too.
They're only cost effective over a very long period of time though. The filter costs two times more than stock + the cleaning kit. Dealers change the filter every other oil change, so it would take ~4 years to break even just on the filter cost. Also a risk that you could over-oil and destroy your MAF.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
