Bought a '99 528i....overheating, pulled codes
Got my hands on a cheap '99 528i, car was smoking white thicker than average smoke...overheated on the way home. Needle didnt completely hit the end of the red however it remained in the red. I'm thinking blown head gasket or cracked head...
These cars really dont like to overheat -- if it gets in the red you need to shut them off ASAP.
Have it pressure tested but coupled with the white smoke it does sound like a head failure. |
Vacuum leak can cause a lean mixture.
At very least, do a compression measurement and/or cooling system pressure test.
Ed in San Jose '97 540i 6 speed aspensilber over aubergine leather. Build date 3/97. Golden Gate Chapter BMW CCA Nr 62319. |
Ya it's hard to say how long it's been overheating since it was at an auction but I'll assume the worst for now. Hoping for a non-cracked head after my Indy tears it down tmrw.
Car is pretty solid otherwise, sad to see it overheat. Any other components/parts I should replace while its apart? It's a 1999 528i with 160k, no leaks as of yet... |
Entire cooling system.
http://www.bimmerboard.com/forums/posts/199986
Either you are part of the solution, or you are part of the problem. |
Suspension - front and rear.
Either write something worth reading or do something worth writing. Benjamin Franklin 2001 530iA Steel Blue/Sand - Sport/Premium/Cold Package 1999 528iA Jet Black/Black - Sport/Premium/Heated Seats 1999 528iT Cashmere Beige/Sand - Sport/Premium Package - 5 speed 1982 Fiat 2000 Spider - Blue Metallic/Blue |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
