Old 03-21-2013, 12:27 PM
rtl1369 rtl1369 is offline
Mein Auto: 2001 530 sport
Inconsistent interior heat - slight antifreeze smell
Hi,
2001 530 125,000 miles. Replaced the cooling system 5,000 miles ago. My interior heat is inconsistent. At times hot air blowing from the driver side only, then cools down to barley warm. Recently noticed a very slight antifreeze smell, but no slimy interior windows or other evidence. Car runs at normal operating temp, has not overheated.
No leaks after being parked. My thought is the heater core is going bad. Called my local shop and they said heater core is very uncommon, and probably something else.
Advice to help diagnose much appreciated. Any helpful links to change out a heater core, if turns out to be the problem.
Tim
Old 03-21-2013, 12:36 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Damp carpets? Does the coolant level drop? Intermittent heat can signal air in the system, which can enter via leaks.
Heater core failure on the E39 is very rare, except for those cars not properly maintained.
