E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008)
Coupe and Roadster talk with our gurus here... |
According to the "BIMMER" magazine:
"Since the S54 engine has the mechanical method of valve actuation, which replaced the hydraulic lifters used on the S52 engine, it requires periodic inspection and clearance adjustments every 15,000 miles, depending how the engine is run". My S54 engine has always had more valve noise than my S52 engine. It is my understanding that as the S54 valves start to need to be adjusted, they make even more noise. Is this true? I have 21K miles on my S54 engine and have not had the valves adjusted. I am interested in hearing from other S54 owners about when they had their valves adjusted. The BMW dealer talked me into another year of BMW dealer maintenance for $425. They said that the "Inspection I" on the S54 engine, which I believe includes a valve adjustment, costs over $900, if done without part of the maintenance. Comments?
BMW Z4 Coupe 3.0si (2007) - Jet Black exterior - Red leather interior - 6-speed - Sports Mode - Sports Suspension - BBS CH 18" wheels (8.5" & 10.0") - ///M Sport Seats |
Bimmer was the first to report that (I have that issue too) but the information is wrong.
The first valve service is at Inspection One, second at Inspection Two, etc. Your valves are noisier than in the S-52 because it has "hydraulic lifters" (so to speak) between the cam lobes and valve stems. The S-54 operates the valves from the cam via a small rocker arm and is metal on metal contact or "solid lifter" actuation. Yes, they will become noisier as wears allows greater lash. Remember this truth: noisy valves won't cost you money (but tight ones will)! My 01 hit Insp I at 21,000 miles and the valves were all found to be within spec; no adjustment (made with varying thickness shims) was needed.
![]() Randy Forbes 1957 Austin-Healey 100/6 Wine Red 1961 McCulloch R1 go-kart Screaming Yellow 1999///M Rdstr Cosmos Black 2001///M Rdstr Steel Gray 2011 X5 35i Sport Deep Sea Blue/Cinnamon |
Is there a DIY for the valves? What tools do wee need?
2001 Alpine / Schwartz Coupe 2001 Estoril / Estoril Coupe 2001 Steel Grey / Estoril Coupe 1999 Estoril / Estoril Coupe Sunroofs are for girls. |
Ron has posted the (few and basic) tools required here about three years ago (search function should turn that up). Most costly aspect of adjusting the valves yourself is to have the correct shim assortment on hand. Alternative would be to tear it down, record the lash (for 24 valves) and then remove/measure the ones out of spec and order the correct replacement shim. There's about a hundred dollars worth of seals and gaskets required; they are available to the dealer's mechanic as a "kit" but I think we'd have to order all the parts individually. Not a big deal.
![]() Randy Forbes 1957 Austin-Healey 100/6 Wine Red 1961 McCulloch R1 go-kart Screaming Yellow 1999///M Rdstr Cosmos Black 2001///M Rdstr Steel Gray 2011 X5 35i Sport Deep Sea Blue/Cinnamon Last edited by Randy Forbes; 08-07-2004 at 07:48 PM. |
Who is Island internet? Contact info please?
http://rust.mine.nu/bmw/ I'll check the price with Paul Monday. Will be doing my first check somewhere around 30K after HC. The gaskets etc. are on order. |
We need to get a group of S54 owners to chip in and buy a shim set. It's a waste of money for each owner to have his own set. When you want to do your valves, find out who used them last and have them shipped to you.
One note about Randy's reply to Dennis: The sole purpose of hydraulic lifters is to dampen the valve train noise. Because the oil in the lifter will "compress" slightly, the valve train can be run with zero lash, which eliminates the clacking. But in a high performance, high revving engine, that hydraulic cushioning creates a slight deviation (lag) in valve timing and lift. Plus variations in the hydraulic lifter height adds to the problem. Modern hydraulic valve trains, with variable valve timing and overhead cams, have come a long way, but if an engine has an 8000 rpm redline, you can bet it has mechanical (non-hydraulic) valve actuation.
John 01 M roadster, F: GC/Koni short coilover struts, Eibach, Wilwood front brakes, GC tubular swaybar. R: TC Kline springs, short Bilsteins, IE sub & swingarm bushings & shock mounts, 3.23 gear, Rogue dual-ear cover, Eisenmann 4x83 pipes. MISC: Sport mode, Rogue pulleys, keyless, RG Motorsport intake, OZ Superleggera 18" 3 piece. 06 Hemi Durango 04 G35 Coupe 05 Scion xB 07 Scion tC 89 Reynard F2000 |
I should ask my father about that one, he'd remember who the first engine manufacturer was to introduce them (in America) and why.
http://www.bimmerfest.com/forums/sho...t=valve+adjust |
Daniel 2002 M roadster |
Higher revving engines use mechanical lifter to keep from " floating the valves"
the hydraulic lifter are used for a no maintenance and sound aspect. |
I agree that reduced maintenance probably was the biggest reason for the popularity of hydraulic lifters, but to say noise didn't matter? Sorry, don't agree. Whether they were designed to be quiet, or it just turned out to be an additional plus, once hydraulics started making noise, people complained. It was a rare day back in the 60's, when we didn't have a noisy hydraulic lifter to replace in my uncle's shop.
Randy, In my years of racing cars and motorcycles, I'd like to have a dollar for every time I dug through someone elses shim collection at the track looking for the one I needed. I considered it lucky if I found one, and not once did I ever think, " I can't use this; someone else had their hand on it."
In your first reply in this thread, you said, and I quote: "The sole purpose of hydraulic lifters is to dampen the valve train noise." Sorry, I don't agree. While noise reduction is a benefit, I doubt it was the motivation for the design. Better sound insulation would've been easier and more profitable. Where did I say noise didn't matter?
![]() Randy Forbes 1957 Austin-Healey 100/6 Wine Red 1961 McCulloch R1 go-kart Screaming Yellow 1999///M Rdstr Cosmos Black 2001///M Rdstr Steel Gray 2011 X5 35i Sport Deep Sea Blue/Cinnamon Last edited by Randy Forbes; 08-08-2004 at 04:37 PM. |
The ones I purchased separately were less per shim. |
I ordered mine through Jay Lilley.
Valve adjust parts
Ordered some valve parts to see how the shims fit and how the retaining clips come out, which wasn't clear (to me) in the instructions. It is now.
Anybody know BMW's reason for using shims? My hondas were all adjustable with a bolt and locknut.
Jon Maddux 10 S1000RR | 09 F650GS | 08 E90 M3 | 07 R1200RT | 06 M Coupe | 01 M coupe |
Jaguar XK & Lotus DOHC valves are adjusted with shims too. Probably Ferraris too, but I haven't had one of those apart yet... Most DOHC setups require lifting out the cams (well, British anyway) to change the shims, at least the BMW has sidestepped that task. Edit: As I remember, part of the design criteria for this engine/cylinder head was to reduce valvetrain mass for higher RPM operation. Hence the lighter components (tiny-tiny shims) and hollow gun-drilled camshafts.
![]() Randy Forbes 1957 Austin-Healey 100/6 Wine Red 1961 McCulloch R1 go-kart Screaming Yellow 1999///M Rdstr Cosmos Black 2001///M Rdstr Steel Gray 2011 X5 35i Sport Deep Sea Blue/Cinnamon Last edited by Randy Forbes; 08-13-2004 at 08:16 AM. |
The different ways of going about doing the same thing are interesting, seeing as how both companies make excellent, high-revving engines. |
shimsss
I like the the kit Randy!p/s to the man that wants to share my freinds do not share tools.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
