Old 03-21-2013, 02:23 PM
CAX5 CAX5 is offline
Mein Auto: 2014 M5
Broke Down on Freeway-Advice?
So I am driving this morning on the Freeway and start to hear a humming noise, first I thought it sounded like a bad wheel bearing in front. Then it started to get really loud, so I moved to the right lane, then I heard a loud metal Snap !! Pulled over and saw this on picture below. If you look the metal cover nearby is bent, but I did not hit anything. The dealer said it looked like I did hit something, but said they will check it out and let me know. Oil flooded the dealer lot after the flat bed dropped it off. Looked like transfer case fluid.
Name:	2011 X5 on Freeway 0313.jpg
Old 03-22-2013, 06:40 AM
ard ard is offline
Resident Curmudgeon
I seem to recall someone posting about this a year or so ago. Same issue, broken Ujoint at transfer case, oil, tow.
A BMW tech chimed in about this as well
GL
This isnt road debris, IMO
A
Old 03-22-2013, 06:57 PM
norcal norcal is offline
Mein Auto: '15 x5d MSport
GL
A
Yes, I think I remember somebody from Atlanta over on Xoutpost...
Old 03-22-2013, 07:02 PM
finnbmw's Avatar
finnbmw finnbmw is offline
Mein Auto: 2010 & 2012 X5 35d
You have excellent memory http://www.xoutpost.com/bmw-sav-foru...aft-today.html
Old 03-22-2013, 07:52 PM
5seriesHB's Avatar
5seriesHB 5seriesHB is offline
2 Bimmers R better than 1
Mein Auto: 12 MSPT 535 & MSPT X5 5.0
Not long after the last post, I was notified of BMW approval for a trade assist.
This may be in your future...start looking for a new car...
Good luck!
It will all work out in the end....and if it hasn't worked out yet, its not the end!
2012 Msport X5 +Prem Sound+Cold Weather+Top/Side Cameras+Soft Close Doors+BMW Apps
Old 03-22-2013, 08:15 PM
ard ard is offline
Resident Curmudgeon
Whoop, wrong forum....
killcrap
i've come across this many times, what ive seen is the u-joint that connects to the transfer case on the front drive shaft siezes and breaks off because it is unable to flex correctly, most of the times, it contacts the side of the transmission and you will hear metal to metal contact and you will see wear marks on the side of the transmission casing.
Killcrap is a BMW tech.
Op, keep us updated...it will be VERY easy to see if it was rosd debris or a warrantable part failure.
GL
A
ard ard is offline
Resident Curmudgeon
Duplicate
Old 03-23-2013, 08:43 AM
Mein Auto: 2014 M5
I think Killcrap's description is spot on. The tech working on the car pointed out where the the U joint broke. The dealer, which I did not buy the car from, has been great. They ordered a new Transmission and drive shaft, and the SA said they probably will replace the transfer case along with a long parts list they showed me. They gave me a new X3 to drive, so all good right now.
