The X5 SAV Forum
Old 03-22-2013, 04:01 PM
bobsx5 bobsx5 is offline
Mein Auto: 2001 X5 4.4
Squeel on start up
My 01 X5 4.4 has a squeel on start up that sounds like a belt to me. I have been told it's the water pump. Could this be accurate?
Old 03-22-2013, 06:22 PM
Tanny Tanny is offline
Mein Auto: 2008 BMW 530i LCI
usually happens if a belt is too tight. Hard to diagnose as you havent specified where in the engine bay the noise is coming from.
Old 03-24-2013, 08:57 PM
Shogan Shogan is offline
Mein Auto: '08 535xi or '02 X5
Belt tensioners have springs (or hyrdraulic). My 02 x5 needed these. I identified by using long screw drive held handle to ear tip to non moving part close too tensioner. Yes while car is running. Be careful. There is stethoscope for this but I don't have one in my TBox.
Old 03-25-2013, 09:33 PM
Shawnv Shawnv is offline
Mein Auto: E38 & X5
Just in case: On one of my other vehicles it turned out the squeal was do to the rubber seal failing in the harmonic balancer/Vibration damper. This was the first time I ever heard of or delt with that. So, figured I would chime in. Do/t check while wearing a tie!!
Old 03-26-2013, 07:47 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
hard to say, but if you hear the squeel at start up and it goes away after 3-5 sec then yes WP is supect, tensioner seems to squeel on peridoic interval continuosly.
At least on mine it squeeled at start up and it's the WP bearing on the way out.
Old 03-26-2013, 11:18 AM
Zulu95's Avatar
Zulu95 Zulu95 is offline
Mein Auto: 2001 X5 3.0L
Just to throw something else into the mix: If it only happens on a cold start-up then it could be the secondary air system pump failing/failed.
GL.
Old 04-02-2013, 12:35 PM
TL555 TL555 is offline
Mein Auto: BMW X5 4.4i
i had a squeal on morning start. my mechanic suggested we check out the belt and tension pulleys, turned out the lower pulley wasnt "rolling" smoothly. To avoid having to go back there, i bought all new pulleys and the belt and also checked out the water pump, which was beginning to loosen. just as well, problem sorted. while at it, i also noticed an oil leak on the oil pressure switch and we just did one job, problem solved,
Old 04-09-2013, 05:55 PM
Thanks for the input all. I will have both vhecked out. Just wanted to try and narrow thing down.
