Old 03-22-2013, 04:18 PM
LIMAJAMM LIMAJAMM is offline
Mein Auto: 2004 BMW X3
04 x3 2.5
My vehicle was cranking but not starting. It had the original battery in the car at 93,000 miles. We switched out the battery and now I have the 4x4 light and engine light on. I was told it needs to be programmed and that is another 250-300 from dealership and 5 hours of programming. Is there something else that I need to do???
Old 03-22-2013, 04:57 PM
mlukas161's Avatar
mlukas161 mlukas161 is offline
Mein Auto: 03 330i, 04 X3
A 2004 x3 does not need to be reprogrammed after changing the battery. I think it must be something else... Not sure what though.
Old 03-22-2013, 05:18 PM
avoisin avoisin is offline
Mein Auto: 2004 X3 2.5i
I have seen the 4x4 light come on after I mess with battery (removing while doing other service). It has always goes off on its own after a few minutes of driving once I have everything hooked up again. If that's all it is, you might just need to drive around a bit.
If you have the check engine light too though, that's different. I can tell you that changing the battery alone doesn't need any programming, but you may have something else going on.
Old 03-22-2013, 05:35 PM
Thank you. I did drive around a bit and the 4x4 light went out. The car started rough and idled rough and this is why I think the engine light may have come on. It was not on prior, just unable to start after it sat for a few weeks in the cold. The battery was original and the dot was black even after doing a charge on it. So I knew it was a battery issue. Wondering if I drive it a little if it will go out or if the rough idle triggered the light. Seems to be running better now.
Old 03-22-2013, 05:40 PM
Yeah, certainly being left alone for a few weeks is going to gum up stuff, but should loosen up after driving around.
That said, i don't know if the CEL needs to be reset if it gets triggered, maybe someone else can chirp in on that.
Old 03-23-2013, 06:49 PM
fivepointnine fivepointnine is offline
Mein Auto: BMW X3, Hyundai Genesis
The CEL will reset itself when the computer does not see the issue anymore
Old 03-23-2013, 07:03 PM
Thank you. So far it is on still, I am hoping it is just that the car idled rough at first after we changed the battery. Since it was sitting the brakes are a little rough also, grind a little. Any ideas for that?
Old 03-23-2013, 08:52 PM
AzNMpower32's Avatar
Tar Heel Faithful
I would still go get the codes read. The idle on these M54 engines should be very smooth and quiet, as if the engine were off (since I stop-start my engine at long waits, I actually have to check sometimes!). Given the age of the vehicle, a variety of things could have gone away, z.B the air intake boot, DISA valve, CCV, and others that could prompt the SES light.
Old 03-24-2013, 12:51 PM
dukedkt442 dukedkt442 is offline
Mein Auto: 08 E83; '86 442; 84 GMC
Every vehicle will grind the brakes after sitting, as the rotors are bare steel and rust instantly. What to do? Drive it; braking action cleans the rotors.
