Old 03-26-2013, 08:18 PM
F1.tifosi's Avatar
F1.tifosi F1.tifosi is offline
Send a message via Yahoo to F1.tifosi
Mein Auto: BMW 535i Sport, 08 Accord
Originally Posted by Oceans10 View Post
Check with Cobb re E85 recommendations. I know the LPFP becomes a liability at levels above 45%. Still at that rate you are close to 100 octane when mixing with 93 octane. N54 loves that!
Sure Peder, I will check with them.. Thanks
Jet Black | LCSW | DP WT | ZCW | ZPP | ZSP | 261 | 2TB | 322 | 415 | 416 | 609 | 610 | 620 | 677 | 6FL | 6UH |F/R Cameras | Escort 9500ix |
Old 03-26-2013, 08:22 PM
F1.tifosi's Avatar
Originally Posted by booyaazaa View Post
Damn I wish we had 93 for premium in Cali. Well you can mix in a couple of gallons of e-85 in with your 93 like Peder said however don't go 100% e-85. Even with a couple gallons mixed in I was able to feel a little bit of difference. The big difference was when jake at PTF sent me my first e-30 map the third 3rd gear pull I did the car just moved through the rpm's like butter. I was so thrilled that I didn't realize I was going 100 mph.
I will go with what PTF suggests when i meet them, i'll double check with CObb as well... This is so much fun and waiting for the day..
Old 03-26-2013, 08:26 PM
F1.tifosi's Avatar
Coming from the JB4 world, the recommendation is not to go higher than 45% E85, else the LPFP can't move fuel adequately out of the tank and up to the HPFP. My guess is that Cobb is similar as this is a matter of physics, not software. E85 is much denser and heavier to move than regular gasoline. This is why people replace the stock LPFP with a high output Walbro when they go to higher mixtures or larger turbos.
I actually now have Cobb as well and use it to manage fuel, whereas the rest of the tuning management is done by a stacked JB4 race map. The difference is that I can now run the engine further up the rev band without dropping in power. The pulls are stronger up top, north of 5,500 rpms, due to the Cobb fuel management. Best of both worlds I guess. I am on about 40% E85 and 93 with FBO and 70% meth. Boost target is 18.5 psi, so with up to 1.5 psi overboost allowance I hit 20 at times.
So Peder you go with almost 11 gallons 93 octane and the rest E85? How do you judge these when filling, or is it 3/4 (93 octance) and 1/4(E85)?
Old 03-27-2013, 06:59 AM
booyaazaa's Avatar
booyaazaa booyaazaa is offline
Mein Auto: '09 AW 535i, Fiat 500e
Depends a bit on how much ethanol is in the 93 oct that you use. If it already has 10% ethanol (e-10) in it then you would mix 5 gallons of e-85 and 13.5 gallons of 93 oct to get a e-30 blend. The very first tank I did I ran the tank almost empty (don't do this too often) and then made my mix, ethanol first and the rest gas. After that i usually fill up at the half tank mark with 2.25 gal e-85 and 6 gal of 91 oct. Even though our tank capacity is 18.5 gal the half way mark isn't really 9.5 gal but a little less. Guess there is a reserve amount of gas that they factor into the gauge. I use this site to help me with the calculations. http://www.intercepteft.com/calc.html
If someone has an easier method I'm all ears.
2009 AW 535i
-Sport, Premium Package, and Comfort Access
-FBO, custom Cobb E45 map, Fuel_it Stg2 LPFP, Performance Gearing LSD.
Follow on IG: Booyaazaa
Old 03-27-2013, 08:28 PM
F1.tifosi's Avatar
Thank you Booyanazaa.. You are right i have noticed that the mpg shows differently on both half of the tank..
Appreciate your detailed explanation.. I'll consider these factors when i start mixing the E85.
Old 03-29-2013, 03:00 PM
F1.tifosi's Avatar
Nice. Damn I just noticed you have RB turbos in your sig too. Your 5er will be blazing fast.
Peder you better let us know, waiting to get that added
Old 03-30-2013, 07:37 AM
F1.tifosi's Avatar
