Old 03-22-2013, 04:56 PM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
Another one bites the dust... (coolant transfer pipe on N62)
Well, came out to the car earlier and found this:
Put more coolant in, and it's coming right back out the weep hole.. so I assume the infamous coolant transfer pipe is the culprit. I had seen a small dried up coolant trail from the hole a few weeks back, but figured maybe it was just leaking a little and no big deal. Apparently it went from little bit to whole lot real quick.
So, this will be my thread of fixing it. Any tips would certainly be appreciated.
Old 03-22-2013, 05:00 PM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
Please get this pipe below with the repair. I'm sure you've heard of it. The cost will be hundreds less.
http://www.allgermanauto.com/product/index.html
Old 03-22-2013, 05:01 PM
DIY'er
Indeed, I already had some DIY links bookmarked for this day, lol.
I am torn between that one or the URO one. URO is cheaper and I haven't seen any complaints (so far). I don't mind spending more if I need to.. just don't really want to if I don't need to
http://www.amazon.com/URO-1114143997...=cm_cr_pr_pb_t
Old 03-22-2013, 05:08 PM
boramkiv's Avatar
Propellers Up Front
No problem about which one, just as long as you don't have to take the front of the engine off. I've heard many, many, many stories about that $3000 repair.
The latest one was a guy with a 745i at a tire shop I went to a few months ago. He liked my car and wanted it because he's had it with his 745i. Told me about that repair, and i'm like "nooo dude, you gotta get that pipe." He didn't know about it and was kicking himself after I explained it. He surely kept my number after and gave me a huge discount on the tire repair just for the hindsight alone lol.
Old 03-22-2013, 05:50 PM
SoCaLE39 SoCaLE39 is offline
Mein Auto: E60 M5, E46 325i
Are you sure is the transfer pipe? Reason I ask is because my coolant expansion tank cracked on me and only $100 later I was good to go.
Old 03-22-2013, 06:16 PM
eWERK-E60's Avatar
eWERK-E60 eWERK-E60 is offline
Mein Auto: E60 550i Porsche 911SC
Man sorry to hear this... Hope fix isn't too $$$.
“Racing is life. Anything before or after is just waiting.”
Steve McQueen
Old 03-22-2013, 06:17 PM
DIY'er
edit / update 4/10/2013: Please see later post on actual parts I ended up needing. This was just a first draft.
Here's what I have so far.. changing a lot of small parts while it's apart.
I think I can do the whole thing for less than $500
Qty Price Total
1 Water feed pipe, O-Ring http://www.ecstuning.com/Search/11517507717/ $3.21 $3.21
1 small coolant pipe http://www.ecstuning.com/Search/11511439976/ $15.65 $15.65
1 water pump gasket http://www.ecstuning.com/Search/11517508535/ES24416/ $9.60 $9.60
2 intake manifold gasket http://www.ecstuning.com/Search/11617521181/ $22.77 $45.54
1 valley pan http://www.ecstuning.com/Search/11147507278/ES19430/ $67.35 $67.35
8 injector clip http://www.ecstuning.com/Search/13537528539/ $0.90 $7.20
8 injector o-rings http://www.ecstuning.com/Search/13647509752/ES34578/ $4.92 $39.36
2 valvetronic o-rings http://www.ecstuning.com/Search/7119903596/ $2.32 $4.64
1 hex bolt (water feed pipe) http://www.ecstuning.com/Search/07119905400/ES14707/ $0.99 $0.99
4 Torx-bolt, fuel rails http://www.ecstuning.com/Search/07129904819/ES16077/ $0.99 $3.96
Total $197.50
Old 03-22-2013, 06:19 PM
DIY'er
It is dumping coolant out of the weep hole, so pretty certain that is what it is
(I changed most of the cooling system a few months back also and all the lines are dry)
You can kind of see it here. To the left of the water pump opening
Old 03-22-2013, 06:23 PM
DIY'er
Thanks! Hopefully my apartment complex doesn't get pissed when I rip this thing apart in the parking lot, haha
Have to get a rental car for next week though, so that kind of sucks
Old 03-22-2013, 06:45 PM
DIY'er
edit / update 4/10/2013: Please see later post on actual parts I ended up needing. This was just a draft.
Update:
Little over $400 (before shipping..)
Qty Total
2 intake manifold gasket http://www.ecstuning.com/Search/11617521181/ $45.54
8 injector clip http://www.ecstuning.com/Search/13537528539/ $7.20
8 injector o-rings http://www.ecstuning.com/Search/13647509752/ES34578/ $39.36
2 valvetronic o-rings http://www.ecstuning.com/Search/7119903596/ $4.64
4 Torx-bolt, fuel rails http://www.ecstuning.com/Search/07129904819/ES16077/ $3.96
1 Coolant pipe kit http://www.ecstuning.com/Search/11141439975R/ES2568197/ $229.00
Total $426.50
Old 03-22-2013, 06:55 PM
champaign777's Avatar
Mein Auto: 2003 530 Sport Twins
and the miles on car is ...
DIY'er
Take a wild guess ...
(190K as of earlier this week)
Old 03-22-2013, 06:56 PM
JFIVE JFIVE is offline
Mein Auto: 545i
I feel for you, had the coolant pipe kit done on mine when I bought it last summer
Fortunately for me it was at the dealers expense, It started leaking/ pouring out the weap hole two days after I got it
Also got th
Sent from my SPH-L710 using Bimmer App
Old 03-22-2013, 06:57 PM
Mein Auto: 545i
Also got a new water pump
Old 03-22-2013, 06:59 PM
DIY'er
For the miles on mine, I can't complain. This was one of the last of the most common complaints
Old 03-22-2013, 07:02 PM
DIY'er
edit / update 4/10/2013: Please see later post on actual parts I ended up needing. After I got into it I ordered more parts
Quantity Each Total
ES#24414 O-Ring ES#24414
See MOQKT
11517507717 1 $3.21 $3.21
ES#24361 PIPE ES#24361
11511439976 1 $15.65 $15.65
ES#24416 GASKET ES#24416
11517508535 1 $9.60 $9.60
ES#25751 Intake Manifold Gasket - Priced Each ES#25751
Fits both left and right
11617521181 2 $22.77 $45.54
ES#19430 Valley Pan Cover With Seal ES#19430
Located in between the cylinder heads beneath the intake manifold.
11147507278 1 $67.35 $67.35
ES#33675 Fuel Injector Holder - Priced Each ES#33675
Clips into the fuel injector
13537528539 8 $0.99 $7.92
ES#34578 O-RING ES#34578
13647509752 8 $4.92 $39.36
ES#2597506 O-Ring ES#2597506
07119903596 2 $2.32 $4.64
ES#14707 HEX BOLT ES#14707
SEE MOQKT
07119905400 1 $0.99 $0.99
ES#16077 TORX BOLT W/WASHER ES#16077
07129904819 4 $0.99 $3.96
ES#2568197 Collapsible Water Pipe Kit ES#2568197
Effectively and easily addresses a common point of failure in the N62 4.4L and 4.8L V8!
11141439975R 1 $229.95 $229.95
Sub Total: $428.17
Shipping - (UPS - Next Day Air Saver): $36.06
Total: $464.23
Old 03-22-2013, 07:07 PM
boramkiv's Avatar
Propellers Up Front
Just be aware of your complexes policy on vehicle repairs. You really don't want to add that to the headache mix. It's still a big job as easy as it may be, and neighbors can report you. I would just inform the front office if its against their policy, and let them know it would take no longer than a weekend. The hood can be closed/vehicle secured so the car won't look a wreck sitting there.
Old 03-22-2013, 07:13 PM
DIY'er
Will do.
Yeah, I should be able to do it in a weekend easy. If I have the parts by end of the week hopefully I can use the extra day off on Friday to knock it out!
I thought about ordering the vacuum pipe thing that goes between the valve covers & intake but it would have added $100. Hope I don't break the old one getting it off!
Old 03-22-2013, 08:50 PM
Thats some good mileage you are getting out of her. I'd say you had a good run prior to this!
Old 03-23-2013, 08:59 AM
eWERK-E60's Avatar
LOL. Just make sure you have a folding chair, radio and cooler full of beer when you fix your ride, management won't say anything.
Steve McQueen
Old 03-23-2013, 09:00 AM
DIY'er
Yeah, can't complain. It was due for this to happen
lol, yes sir!
Old 03-23-2013, 09:13 AM
Vapiano's Avatar
Vapiano Vapiano is offline
Mein Auto: Dinan E60 M5 & 2014 550ix
Sorry to hear this, we were just chiming in on this subject a few weeks ago! Good luck with your repair.
2014 550i xDrive, Alpine White, Black Merino, Anthracite Wood, M Sport, Premium, Executive, and Cold Weather Packages, HUD, Ceramic Controls, Comfort Access, Sport Automatic Transmission, 4 Zone, Soft Close Doors, Power Trunk, Fully Coded, M Performance Spoiler and Black Grilles, 28% Tint, Charcoal Filter Delete, BMS Stage 1, Dinan Performance Springs, Bavsound Stage 1 Premium Kit w/subs, Beltronics STiR+
Old 03-23-2013, 02:38 PM
DIY'er
Pictures! Only took about an hour to get the intake off. Wasn't nearly as bad as I thought it would be. I have to do some major cleaning before putting it back together though--a bit of dirt/grit got down into the intake runners and is sitting on the valves. May be fine but I really don't want to risk it.
Looks like the coolant pipe running from the expansion tank to under the intake had some leaks as well--I found cruddy green stuff all over the place. I ordered a new one of those and ordered new crankcase ventilation hoses. This put another $170 on the tab though.. so I'm over budget, but oh well.
Old 03-23-2013, 02:57 PM
eWERK-E60's Avatar
Hey great job! Stuff some paper towels in the intake ports to avoid contaminates.
Steve McQueen
Old 03-23-2013, 03:03 PM
DIY'er
Thanks! I covered the ports with painters tape for now (didn't have any paper towels and didn't have enough rags, lol)
