Old 03-22-2013, 05:59 PM
Friscobeemermom Friscobeemermom is offline
Mein Auto: 740il
Wink 2001 740 il - Single mom needs headliner advice
Can anyone answer some headliners questions for me? Single mom wants to make sure she is being told the truth regarding my headliner in my 2001, 740 il.
I was told the entire liner needs to be taken down and redone. Otherwise it will not adhere to the existing dried adhesive. Is this true? How much should I expect to pay? How many yards will it take? I do have a sunroof but it is fine (it is retractable).
I love my car and know alot about it for a chick!!! I'd love to learn more about my car. I'm searching for several accessories too. Can anyone tell me where the best place to buy used parts or if I need to buy new? If you would also be so kind as to give me the names or several websites.
Thank You,
Laura
Old 03-23-2013, 01:46 AM
scellpt scellpt is offline
Mein Auto: BMW 2003 735I
Which country u live in. Also wat is a head liner
Old 03-24-2013, 08:36 AM
First740i First740i is offline
Mein Auto: 740i
Why is the head liner coming out in the first place?
Sent from my DROID4 using Bimmer App
Old 03-24-2013, 08:45 AM
Just age really but very easy fix with some clue but u should go to a car upholstery agent
Old 03-24-2013, 08:53 AM
Mein Auto: 740i
They sell spray glue for this type of an application. It is easy to use just make sure it not freezing or super hot outside when you do it. Imake sure you left it tack up before putting head liner back up.
Old 03-24-2013, 11:50 AM
wilk187's Avatar
wilk187 wilk187 is offline
2001 740il Sport, RIP
Mein Auto: 2006 750i Sport, '14 GTR
all of the following sites are great for oem (original bmw parts) or aftermarket parts. several offer free shipping over $50:
www.oembimmerparts.com
www.getbmwparts.com
www.autohausaz.com
and when all else fails, ebay.com
Cold weather, PDC, BMW Ipod interface, Valentine1, MTecV2 Angel Eyes,
LED Lic. Plate Lamp, JL/Kicker sound, Bassknob, 21" Style 128's, 5mph autolock
Old 03-24-2013, 12:41 PM
Espresso Espresso is offline
Coffee Extraordinaire
Mein Auto: 2001 740i Sport
headlinerexpress.com
4 yards $260 OEM headliner WITH foam. Headliner itself easily comes out..... better with two people, from the drivers side rear door.
I am redoing mine with microfiber. $50 total. Not typical so do not ask where, or how.
Old 03-24-2013, 01:59 PM
Mein Auto: 740il
thanks for your help
I'm new to the forum not quite sure how to use it. I do have a couple of questios.
Laura
214-529-9681
Old 03-24-2013, 03:16 PM
crcuevas crcuevas is offline
Mein Auto: 2001 740il
Where do live. There are couple DIYs on this site that shows how to do it if your willing to take on the task yourself. I got the same problem.
Sorry just saw where u live
Old 03-25-2013, 06:52 AM
chrisn7 chrisn7 is offline
Mein Auto: 750iL
I believe this is messy job to do as the old foam backing has to be scraped off before the new fabric can be attached. There is a pictorial write up somewhere and it was stressed that all the original orange goo/foam has scrupulously to be removed, as it can stain the new fabric if transferred by fingers etc. Also there is very specific method for removal of the headliner through a rear door to avoid damage. I don't think you could describe this as an easy fix at all...Ah I just found the post with loads of pics
http://www.bimmerboard.com/forums/posts/566588
Old 03-25-2013, 07:41 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Add www.e38.org to your bookmarks/favorites folder...when you go there...you'll see links to most every common failure/mod/upgrade that has been done to the e38 since they debuted in 1995. Even if you plan on having someone else fix it or do it...at least you can get a heads up as to what the fix/mod/upgrade entails.
For instance, there's approx 6 DIYs for the headliner...and there is also a list of BMW dealers and non-dealers as to where to find/buy parts (new & used).
And yes, the whole headliner needs to be removed...and all the old adhesive and foam left from the headliner material that has separated needs to be removed (scraped) and cleaned before reapplying new material. If this isn't done...you'll see all your hard work or hard earned money gone to waste as the new material begins separating from the headliner. Any of the old foam left will continue to crumble & detach from the headliner...it is an unstable base to reattach new material too.
Q {BMW CCA Member #191509}
(SOLD)
Old 03-25-2013, 05:19 PM
PaystarCEO PaystarCEO is offline
Mein Auto: 2000 740IL
This (for me at least) is NOT A DIY project.
"Easy" is truly a relative term in these forums ... so for me, a true blue NON-DIY'er, this is one of the worst projects I could have taken on (and I didn't).
There are a lot of parts of the interior that have to be carefully removed and then put back.
And the scraping is totally unpredictable - it could take hours or days.
Furthermore, any efforts by me to save costs on my own headliner project only lead to many more problems.
If I had to do it all over again, I'd go with the guy that did it the second time around (to fix all the problems from the first time when I "saved" a lot of money).
A true professional upholstery specialist is what it took for me to get the job done right. About $600 is what it cost, after spending an earlier $250 to get it done cheaply.
Hope that helps.
HTML code is Off
