Old 03-22-2013, 11:49 PM
DCC DCC is offline
BMW Fan
Mein Auto: '02 Z3 M Coupe
Another RFT vs Non RFT
My question is alittle different...
For those of you with this knowledge, please share your opinion:
On a 35i without AD, will a set of 214s on regular tires ride the same/better/worst than the stock 19s with RFTs?
Thanks in advance
2016 320i Sedan
2011 M3 Sedan
2002 Z3M Coupe
Old 03-23-2013, 12:55 AM
ard ard is online now
Resident Curmudgeon
IMPOSSIBLE without knowing which tire models you are comparing!!
Old 03-23-2013, 07:36 AM
DCC DCC is offline
BMW Fan
Here are the 2 tire models
19" = http://www.tirerack.com/tires/tires....odClar=Premium
20" = http://www.tirerack.com/tires/tires....vity%20Package
The 19s are RFT and the 20s are not
2016 320i Sedan
2011 M3 Sedan
2002 Z3M Coupe
Old 03-24-2013, 10:24 AM
soldmystang's Avatar
soldmystang soldmystang is offline
Mein Auto: e70, e36, e90, e46iT, 6.0
I think the question here is "what are you looking for?".
Given the cars listed in your sig, I would say you will be happier with the Contis. I can't speak for 20s since my '08 is a work truck and I have 19s with non-RFTs. The 20s add a different dimension IMO that precludes bouncing around jobsites and everyday use. I could be wrong but they looking "waxer-esque" to me.
I had the Bridgestones for the first 30K miles. I am at 109K and on my second set of Toyo Proxes STIIs. Less unsprung weight and better grip over the RFTs.
Old 03-25-2013, 06:51 PM
DCC DCC is offline
BMW Fan
I guess i really was trying to get an opinion on whether the 19 run flats ride harder than a set of 20s non run flats...or is it pretty much the same trade off with the difference in sizes.
2016 320i Sedan
2011 M3 Sedan
2002 Z3M Coupe
Old 03-25-2013, 07:07 PM
I wouldn't have the 20s. They are pretty, but really I see no way that they enhance the performance of the vehicle. Now if you are just cruz'n ...................
Old 03-25-2013, 09:47 PM
Resident Curmudgeon
People treat "RFT" like it is ONE tire. There are many versions of runflats by many vendors. You cannot make a sweeping generalization.
Michelin has a superior runflat design, IMO. Wouldnt you then be forced to say 'Mich RFT in 19 versus _______ in 20" which is better?'.
If I had to opine I'd say the 19" rft would be superior in handling and ride to the same mich model in the 20.
But totally opinion. Trying to find an informed opinion from people who have actually driven what you are seeking to compare will be a challenge. Especially with "ride harder" as the metric you are trying to define.
I seem to recall that tire compliance varies dramatically with sidewall- it is at least square root and perhaps a higher order...
Sounds like you want to be told "yeah, upgrade to 20s and go non-rft and you'll be fine"
Old 03-25-2013, 09:58 PM
DCC DCC is offline
BMW Fan
You must be referring to the Michelin Latitude Touring model right? I may have to read up on them more, sounds like you are a big fan of them.
I am considering the larger wheels, but not at the expense of giving up more ride comfort from the 19s RFT.
So either size works for me, as long as ride comfort is considered.
2016 320i Sedan
2011 M3 Sedan
2002 Z3M Coupe
Old 03-26-2013, 03:18 AM
ductman's Avatar
ductman ductman is offline
Mein Auto: 2011 X5 35D /2011 M37X
My X came with the Michelin RFT ( 18in ) , I was happy to see them instead of the Bridgestone's, I found the Michelin's noisy and harsh riding and just chaulked it up to it being a RFT, I needed new tires around 30k back in DEcember however the Michelin's were on backorder till April, I had no other choice in RFT and purchased the Bridgestones, I have approx 5k on them and find them quieter, smoother and much more responsive than the Michelin's ever were and yes I do remember how the Michelin's felt when they were brand new. Just my opinion, the Michelin's are not worth the extra 100 dollar per tire entrance fee.
